Question about Canon PowerShot A75 Digital Camera
When trying to turn on my canon camera, the green light flashes, but the shutter doesn't open. What do I do?
  • Canon Master
  • 4,738 Answers
Do you really mean that the camera is taking black pictures? If so, This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Posted on Nov 17, 2010
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
Hi my Canon Powershot SD 750 LCD screen stays black when taking pictures, you can't view them either. The only thing that shows up on the screen is the menu functions, you can look through everything...
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, astuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 05, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Everything looks like it's working on the screen, lights, etc. But when I push to take the picture, it won't take. It just has a muted clicking sound.
Try a mode other than auto, and turn off the flash. Then try taking a picture. Did it work? If so, then your flash is either burned out, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON).
However, it's more likely to be only a break in the safety circuit. Many Canon cameras use some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, tighten loose screws and try moving and replacing any missing screws with one of the others that are still there.
Finally, if it still doesn't take a picture, even with the flash turned off, then the shutter button itself is likely worn down. There's a little plastic protrusion that may wear down with camera use, preventing the shutter switch from fully engaging when the button is depressed. It's a very easy repair to replace the shutter button, IF you can purchase a replacement shutter button. They can be costly on eBay.
Dec 05, 2010 | Canon PowerShot A630 Digital Camera
Camera will not show image on screeen or in veiw finder. Green status light is on.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot S2 IS Digital Camera
Canon power shot s3is, picture quality is not good, we have use flash every time. otherwise images are very blurred and dull. what change i have to made to my camera. any suggestions will help full for me
If you can are turning the flash off and on, you are no longer in the "Auto" mode. Rotate the top selector dial to select the green "Auto" position. This will enable the camera to automatically select the best aperture and shutter speed based on the available lighting. It will also decide whether it needs flash or not.
As you gain confidence in your abilities, experiment with the other settings on the dial. May I suggest first trying the "P" program setting. This is similar to auto, but will enable you to turn off the flash during low-light level shots. Still the camera will select the best aperture and shutter speed based on the lighting. But in very low lighting, you may have to keep the camera extra steady (such as with a tripod) to minimize camera shake as the picture is taken.
Sep 27, 2009 | Canon PowerShot S3 IS Digital Camera
Flash won't shoot
does the red bulb show when the flash is ready to shoot ? you can press the button that lights red or green to test the flash on itself.
Mar 10, 2009 | Canon Speedlite 550EX TTL Flash
Flash
Your camera is set at twilnight mode which has the flash suppressed and you won't be able to turn it on because of the fixed setting of twilnight mode to get the proper result of the picture. Due to the mode setting requirement, a shakey hand icon and no flash icon will show. If you press the flash mode button, it beeps. The twilnight setting has a low shutter speed, i.e. the shutter opens longer to allow more lights in, therefore it shows recording to let you know that the shutter is still open, and any moment of the camera will result in a blurred picture.
Now, check your camera mode dial and turn it back to the 'green' camera and see if you can get the flash to fire.
Jul 08, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Dance Recital Pictures
try bring a tripod or monopod with you-you can than turn off the image stabilizer if doing this-this will allow the cameras shutter to stay open longer and take in more light. Things to try-turn flash off-use a high speed memory card-change iso and exposure values manuely-use a scene mode or put camera on a or p mode which is shutter or appeture priority and see what changes-must set up early and try different settings-try a external flash to boost your range
Jun 04, 2008 | Canon PowerShot S2 IS Digital Camera
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
May 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Indicator ight
If it turns orange, it only means that the flash will be used. Green is when the flash will not be used.
Do you get an orange light?
Hope this helps!
Mar 04, 2008 | Canon PowerShot A720 IS Digital Camera
Canon PowerShot A75 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
