Question about Honeywell Programmable Thermostat Heater
I have a honeywell ct3400 thermostat and I'm having problems with the heat coming up' I use the settings: morning, daytime, night, and evening but the heat doesn't come up. Is there some kind of video demo so I can see if I'm doing something wrong. Thanks in advance for your assistance.
SOURCE: HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Posted on Oct 27, 2008
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
machtcl1
  • 61 Answers
SOURCE: heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Posted on Dec 16, 2008
  • 96 Answers
SOURCE: heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Posted on Dec 28, 2008
  • 252 Answers
SOURCE: How do I open the Honeywell programmable
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page.
Posted on Oct 05, 2009
I need to clear the program in my Honeywell model # CT3600A4
OWNER?S GUIDE
Honeywell CT3600/CT3697
PROGRAMMABLE THERMOSTAT
9k=
Dec 26, 2014 | Heating & Cooling
Honeywell CT3400. New batteries but touch pad has become unresponsive
Turn the furnace power off for 10 minutes (the control wiring up to your thermostat is powered from a transformer in the furnace) & turn it back on. Make sure you have 24 volts to the Red wire on the thermostat.
Nov 21, 2013 | Honeywell Programmable Thermostat Heater
The furnace comes on @ 70* when programmed to be 60* at night
you have to switch it to settings and reprogram it. find your owners manual and it will tell you how to program your thermostat
Dec 01, 2012 | Honeywell Programmable Thermostat Heater
We just replaced the batteries in our Honeywell CT3400 thermostat, and for a moment or two, the display came on, but the thermostat was not responsive to the touchpad. Now, the there is no display, and we...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jun 05, 2010 | Heating & Cooling
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
How do I open the Honeywell programmable thermostat Model CT3400? I've never done it before and don't know how to open it.
Oct 04, 2009 | Honeywell Programmable Thermostat Heater
Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Oct 24, 2008 | Honeywell Programmable Thermostat Heater
Honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Feb 09, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
282 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
