Question about M-Audio BX5a Speaker
One of my speakers has a constant hum and an intermittent crackle/hiss while music playing. Please help!
Capacitor problem. Open up the case and unplug the cords from the board; if you see any traces of "brown sludge" coming from the caps then this is likely the problem.
I just had this problem myself -- went to the electronic components store and bought 4 new capacitors, a soldering iron, solder ****** and some solder for $25 CAD total, replaced the 4 of them myself in an hour having no previous experience doing such things before, and now the speakers sound better than I think they ever did.
Posted on Nov 28, 2011
    Guru:
  • 2,178 Answers
Swap speakers from the output of the receiver or amplifier. If you hear it from the same speaker, then the speaker is bad.
Posted on Nov 10, 2010
NHT SubOne makes hum when the standby mode is activating and when playing music there are pops when the volume gets loud.
Hums are generally caused by electrolytic capacitors that have gone. You should replace any large ones in the power supply section of the unit.
May 28, 2017 | The Audio Players & Recorders
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
My Mackie SRM-450's both make excessive white noise, one of them crackles quite loudly.
This type of active speaker by Mackie has a issue with operational amplifier ic's inside, they are just those little black things with 8-pin soldered to the pcb, you may have some of them damaged, because of the erratic operation of the units, let me know if i can help more.
Jul 04, 2013 | Mackie SRM-450 System
Hi. When switched on the speaker makes a loud constant crackling sound. Nothing will work, no keys, stops, anything. Just a loud crackle!
This usually means that the speaker is blown. Try running through a different setup and see if it fixes the problem. Hope this helps
Oct 01, 2009 | Music
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Technics amp crackle and ''hiss'' noise
in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
May 25, 2009 | Audio Players & Recorders
RADIO SHOWS STATIONS BUT NO SOUND FROM SPEAKERS
if no sound from both speakers check fuse,
if some hissing or humming on full volume then its a fault in oscilator section
if there is no hiss or hum at full volume its a breakage in the wires of speakers, if one speaker is ok its aagain a wire open problem in out put section
open up the speakers and just apply 1.5 volts dc for fraction of second to the speaker leads , if theres crackling the speaker is ok
also see for torn out cones or stuck cone or speaker coil open.
Jan 16, 2009 | 1992 Mercedes-Benz 190
Speakers hissing/humming
Hi Nate41
you won't do anithyng
may be is a bad resistor inside, that get hot and probably start to do this problem. try disconecting the speakers, and move to other place, more cooler, and try to see if you don't get the hissing and humming sound now. sometimes dust and hot places get to this problem.
beside that, may be a path to a problem.
Nov 26, 2007 | JBL CREATURE II Computer Speakers
M-Audio BX5a Speaker Logo
403 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Richard Hemingway
Richard Hemingway
Level 1 Expert
Don Hart
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
