Question about Horizon Fitness Horizon T91 Treadmill - Inside Delivery!
The running belt motor does not work, everthing else works fine the belt will just not turn- no noise or anything
  • 297 Answers
You need to pull the motor hood off to see if the belt is still on the motor. If it is and the motor is not turning, check the controler ( located on the otherside of treadmill) and you should see a red light on. When you tell the treadill to go.... the red light should start to flash, if it does then you need a new motor. If it just stays lit, you have lost communication from the console ( the upper controls ), and need to find out if something came dissconnected.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 10, 2010
Hi, I've got a Kenmore model 110.70052991 and the drum won't rotate. It will intermittently. I have just replaced the belt and it still won't spin consistently. Could it be the
are u able to spin the drum manually? do u hear any sounds? squeaking? scraping? smell anything? the rollers (spinners lol) usually make funny noises when they go out and may still turn but roughly. Bad bearings may be an issue here? However if the motor has bad windings it may not have enough power to run (turn) drum consistantly, u can remove the drum and belt and housing and run the motor by itself and see if it turns and runs easily. with no pressure or weight added? Then add drum and belt, once the drum is added and it stops or runs half hazardly its ur motor ? In some cases the tensioner the belt sits on ( near the motor) can be damaged and cause similar problems , lastly u did add the belt correctly?
Dec 23, 2014 | Kenmore Dryers
My dryer turns on and heats, but the drum won't turn. I checked the belt and it is fine. No motor noise or anything. What next?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2011 | Whirlpool GEW9250 Electric Dryer
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
NOT BLOWING COLD AIR
Is the compressor motor running off the belt of the motor? Check the fuse for the A/C. Will you have everything running, grab the pipe that runs into the firewall in the engine bay to test for refrigeration effect. If the compressor is running, but no cooling affect is on the pipe, it means that the refrigerant has leaked out of the system at its weakest point. In this case, you will need to take it into a licenced repairer. Good Luck.
May 13, 2009 | Heating & Cooling
My Hoover Deluxe Rewind Elite will not pick up anything. My daughter got something caught in it last night and it made that noise when you get something hung. We turned it off but today it will not work....
When you are saying "today it will not work" do you mean the motor runs, but the unit will not vacuum, or are you saying nothing happens when you try to turn it on?
If the motor run's, the belt probably broke. You will need to remove the bottom of the vacuum part that rolls on the floor, get a replacement belt, and install. Check your owner manual for directions and belt part numbers.
Jan 15, 2009 | Vacuums
Engine whine noise
most likely a belt tensioner or pulley take some penetrating oil and spray the center of each pulley one at a time if the noise stops you got your bad pulley if not take the belts off the motor and spin everything by hand to feel or hear any grinding noises if you still don't feel anything run the motor (not for more then a minute) with the belts off and if the noise is still apparent your timing belt needs to be checked right away! it may be on its way out and if that goes your motor is toast good luck and please rate -jeff
Sep 05, 2008 | 1998 Honda Civic
Toyota 1991 Pickup Truck V6 3.0 engine
the are many possebilities of knocking noises put but listening to what you say try check the engins cam followers
Sep 04, 2008 | 1991 Toyota Pickup
Horizon Fitness Horizon T91 Treadmill - Inside Delivery! Logo
350 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Craig Butler
Craig Butler
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
