I changed the ink in my printing and now everything it prints is blurry.
  • 1,218 Answers
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Nov 10, 2010
Blurry orinting
go to printer settings and go to print configuration and run set up for new cartridges, to align cartridge heads.
Mar 13, 2014 | Epson Stylus NX515 All-In-One InkJet...
Color mismatch and blurry/smudgy prints
Remove ink catridges and clean print head, shake inks and reinstall the inks, if problem persist, Uninstall the driver and reinstall. thats should help. Some time if the print head are dirty it prints multi color. You have to make sure the Head is Clean and install th inks properly.
Dec 10, 2012 | Epson Stylus Photo R1900 InkJet Printer
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
HP 950c printer is printing blurry. This started after changing the ink cartridges any idea what I can do it was not doing this before changing the cartridge and I have used servarl different cartridges.
HI ,
Hope somebody can help, my text is printing the top half of the script blurred but the bottom half is clear! My printer is a canon ip2600. I have newish cartridges and everything has been cleaned and aligned. Cheers
Apr 22, 2011 | HP DeskJet 950c InkJet Printer
My Brothers MFC 210C All-In-One Inket printer is printing blurry. It has been used in a year. I changed the cartridges and ran the cleaner but it still prints light and blurry. What can I do? Thank you.
keep on printing the catridges will satrt function well after few prints if they have ink and heads are ok , if not take out cartridges shake them well chek head are leaving ink on a tissu paper if not place cartridges under runing water tap clean their heads and dry them with tissue paper and place them again nowi think they will work i
let me know your reply sitehr@gmail.com
Aug 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Changed ink cartridges Kodak 5300 print blurry/missing letters
I called Kodak and they are sending me a new printer head at no charge! Can't get any better then that. Man I talked to was very nice, knowledgeable and polite.
Dec 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Logo prints out blurry
It would more likely be the transfer belt then the fuser. Try doing the calibration 3 times in a row and see if that helps.
Press Select (Swoosh)
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 28, 2008 | HP Color LaserJet 2600n Printer
78 people viewed this question
jasbo
jasbo
