How do I replace a broken screen in my HP model # G61429WM? thank you.
  • Computers & ... Master
  • 5,660 Answers
The HP G61-429WM Notebook PC is one of the HP G60 series of Notebook PC's.
I would like you to download (Free) the Service Manual for the HP G60 series Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
On this page go down to the line that starts with HP G50, and click on the blue G60.
You won't see anything happening right away after you click.
This is a PDF file which takes time to download.
[Took 24 seconds for me with a medium speed DSL connection. Entire file downloaded, then the first page popped up ]
After the file has fully downloaded you can save it. Save it to your computer so you can burn it off to CD disk, and then delete it from your computer to save Harddrive space. If you are not aware of how to perform this, and wish to, please state in a Comment.
In the Bookmarks menu to the left, click on the + sign to the left of >
Compaq Presario CQ60 Notebook PC HP G60 Notebook PC.
I would like you to view the Display Assembly in an exploded illustration, so that you can see what the hardware components that you are about to deal with.
Scroll down to the heading > Illustrated parts catalog, and then go down to the sub-heading >
Display assembly components.
Left-click right on the sub-heading Display assembly components.
Number 6 points to the WXGA BrightView display panel that you are going to replace.
You can see there are two cables coming off of the bottom of the display panel.
The one on the left is the Display Panel Cable, the one on the right is the Backlight Cable.
The thin flat plastic frame in the front, that surrounds the Display Panel is the Display Bezel. (1)
The top cover that you see when the laptop (Notebook) is closed, is the Display Enclosure. (9)
The small circuit board at the bottom in the Display Assembly, that you will see when the Display Bezel is removed, is the Display Inverter. (4)
The metal brackets on both sides of the Display Panel are Display Panel Brackets. (5) One on each side.
You have to remove the Display Assembly from the laptop, in order to replace the Display Panel.
Now go back to the Bookmarks menu, and scroll down to the heading > Component Replacement Procedures. Scroll down under this heading to > Display assembly, and click on it.
1) ALL power to the laptop must be removed. AC adapter (Charger), and Battery.
2) You absolutely should buy, and wear an ESD wrist strap when working on a laptop computer.
The cost only averages from $3 to $12.
You don't want to Static shock your computer, and have an expensive doorstop, or paperweight.
Connect the alligator clip to a good ground. I connect to the metal frame of an Empty desktop computer case.
You may not have a similar object around. You can substitute. Use a large metal serving dish, or metal knickknack. Set it on the table you're working on.
(If you have a carpet floor under the table, refrain from swinging your feet across it)
Example of an ESD wrist strap,
http://www.directron.com/1160120.html
Work on a table. A bed or directly on a carpet floor are high areas of Static electricity.
3) Removing the Display Assembly:
A) Remove the wireless antenna cables (2 of them) from the WLAN module
(Page 54)
[ Note* The Black wire connects to MAIN terminal on the WLAN module.
The White wire connects to AUX terminal on the WLAN module.
Just in case you forget, or didn't make notes ]
B) Remove the Keyboard
(Page 57)
[Note* Battery Compartment Cover removed, there are 3 Philips head screws down in the compartment, to remove.
The Keyboard has a cable that connects to the motherboard. It connects to the motherboard with a ZIF connector. {Zero Insertion Force}
The ZIF connector is a two piece affair that slides apart, BUT does NOT come apart in two pieces.
On the plastic connector that you see, are two tabs that are slid forward to release the Keyboard cable.
One tab on each side of the connector.
Slid forward towards the LCD screen.
Use your fingernails to perform this.
The Keyboard cable that comes out of the ZIF connector is a Flat Flex cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg ]
4) Remove the Keyboard Cover. (Page 59)
The Keyboard Cover is the thin frame that goes around the Keyboard.
The Keyboard Cover also has a flat flex cable, and a ZIF connector.
(The flat flex cable is for the Power On switch {Button}, and the LED lights)
5) Now go back to Page 63, and remove the Display Assembly, then remove the Display Panel from the assembly.
Have any questions regarding this, or need a full step by step, let me know in a Comment.
Just one place to procure the Display Panel. Not advertising for them,
http://www.batterycentury.com/hp-g61-429wm-screen-p-134757.html
[ Type > HP G61-429WM LCD screen
Regards,
joecoolvette
Posted on Nov 10, 2010
I have a HP pavilion Dv4, model FR921UA that powers on but screen is black? It of course is out of warranty and HP support was of no help. It worked fine the night before, nothing was done to it. The next...
From what you have specifically said here, It sounds like your graphics car in the HP has failed. This is a very costly service to replace thru HP. Although not necessarily guaranteed, an authorized reseller may be able to fix it for less, but at this point you are better off selling it as broken.
Sep 21, 2010 | HP Pavilion dv4000 Notebook
Broken screen in hp ipaq 910c
hi!!!
try to replaced if it is under warranty
or
buy a new one in the surplus computer shop
near you!!!!
Sep 21, 2008 | Computers & Internet
My screen won't stay open. i think the hinges are broken
Hi. The hinges are either broken or worn out. It is possible to replace them but it can be difficult to find them. I recommend calling around to a few local repair shops as they may have an old one of your model that they are using for parts. Here is a link that shows you how to replace a hinge http://www.insidemylaptop.com/repair-replace-broken-hinges-hp-pavilion-dv9000-notebook/
Also, here is a link to get actual HP parts http://h20141.www2.hp.com/hpparts/CountryChoice.aspx
Nov 11, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
2003 model, HP iPAQ 2210 PDA. Broken screen.
A replacement screen will cost $150+. You might want to get something on Ebay, like the same model with a bad power supply, or bad hard drive, and just swap out the screen. The flat ribbon cables are critical in their placement into their sockets. Make sure the ribbons are well seated, before closing the clamps.
Sep 06, 2009 | HP Computers & Internet
Broken lcd screen, who ,how, make deliveries to east europe?
Consult HP service centre in your area.
http://www.hp.com
Jun 01, 2009 | HP Pavilion dv8000z Notebook
Replacing a broken screen on a HP ipaq 2410
video on yube to open ipaq same kind of procedure
Mar 17, 2009 | HP iPAQ HX2490 Pocket PC
Replacing HP screen
Hi there.
First of all you will need to remove the broken screen from the laptop lid, on the back of the screen you will see a serial number, note any numbers or codes that you see on the back of the screen then use your internet search engine to find a replacement screen with the same numbers or serial as yours.
When you come across one, make sure the serials correspond and that will be your replacement screen.
Good luck and thanks for using FixYa!!
Mar 15, 2009 | HP Pavilion dv9608ca PC Notebook
Broken Screen
ok...the model number is on a label on the bottom of the laptop..that is vital to finding this screen for you
Oct 27, 2008 | Computers & Internet
Tx1320us cracked lcd
If you can elaborate on the exact issue, I will surely try to help.
FYI,
As TX1320us is new notebook, I guess it is one year below model and it should be under warranty.
If you have any issues with the screen, then you can get replacement from HP.
If it is accidental damage, then it won't be covered under warranty. If you have purchased Accidental Damage Package from HP, then all broken and other damages will be covered ADP.
Anyhow, reply if you need any information in this regard.
I will be happy to answer.
Aug 08, 2008 | Computers & Internet
HP Pavilion ZD7000
My name is Brian Rentsch. A computer at my sons school was not working because the screen size was too big for the screen itself. To fix it you might have to restart the entire computer.
Nov 22, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
619 people viewed this question
David Payne
David Payne
