I have removed the board from the unit, but there is not a lot of information on it. On the bottom is “VT60dy(pe1).pcb” and on the top is a white label with “CB47050142”. It has a production date of March 30-2004. But agian, it's not a Haier unit.
Know where I can buy one.
Thanks for the help.
Ron
http://www.haieramerica.com/en/asset/archived/BC112G.pdf is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit. Hope this helps!
Sorry, when you do not unplug the machine before removing the buulb the wires at the bottom of the bulb twist together and blow up the main circuit board. The fuse will not respond fast enough to save the board, the traces that blow off of the board were never meant to carry that kind of amperage and they blow off before the fuse can respond. ALWAYS unplug a microwave to replace the bulb. I have seen a lot of units damaged that way. Need either a new circuit bosrd, or someone to repair the blown traces on that one and test it. Sometimes it damages other parts on the board and you cant turn the light on or off, sometimes always on. New board time, But $$$$
There are a lot of possibilities. If you could give a lot more detail that would be great. Also how long have you owned the tv? Does the tv turn on at all? is there audio? Does the onscreen menu come on? Once I have more information I can assist you further. Thanks, Lee
I would search on Ebay (do a world wide search)
Here is a seller selling the head only.
Item number 380005560333 (UK seller)
There are a number of sellers world wide including Hong Kong and the USA.
Best of luck.
Regards
Alan Hood
ami-man
UK
Item number:
380005560333
Item location:
Kingston, Surrey, United Kingdom
Item number:
380005560333
Item location:
Item number:
380005560333
Item location:
Thanks for using FixYa. The battery replacement in Mio C310 Gps is fairly easy. You can perform the repairs if you have the following equipments--
Tools required:
-precision screwdriver set
-wire (24 gauge or smaller)
-shrink wrap or electrical tape
-wire cutters/stripper
-multi-meter
-sharp utility knife
Please follow these steps--
Remove
the rubber caps and two Phillips head screws at the bottom of the unit
(don’t lose the screws!) Gently pry the back off starting at the bottom
and then work your way up the sides. If you hear the sound of crunching
plastic please re-read the first word in the above sentence.
Once
the back is loose you can pull it down and then away from the main body.
Be aware that the speaker wire will prevent complete removal of the units
back.
Disconnect
the speaker wire plug from the main board and set the back of the unit
aside. The only thing holding the circuit board in place is the USB port.
Simply pry the bottom of the case slightly and lift out the circuit board.
There is a ribbon cable attaching the circuit board to the display so be gentle
with this.
Six
clips (three on top and three on bottom) hold the screen in place. Pry the
top clips back slightly and remove the screen. Now you’ll be able to
remove the batteryu and install a new one.
Please do rate the solution and revert for further assistance.
This means that your V995 has repeatedly failed its internal self-calibration procedures. Like the message says, you need to send it to Beltronics for service.
From my research, I have gathered that it is easier to switch out the circuit board into the unit with the good screen, than to replace the screen. The aluminum tape, which reduces interference between the unit and other electronic devices, can be purchased on eBay for cheap. Many sellers have self-adhesive rolls, or smaller pieces, given one's needs.
It sounds as though you are good with tools and know what you're doing. If you were abvle to remove the circuit board from the unit with the cracked screen, you are obviously able to replace it into the case with the good screen. Although I did do a lot of research for you, I was unable to find detailed instructions that would walk you through the screen removal process.
If
the fuse is good, it may be an open thermostat or thermal cutout (TCO)
/ thermal fuse on or near the magnetron or on top of the cavity / body
of the oven.
There
should be a "mini-manual" (tech sheet) hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
We regularly repair these control units for
customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
i can tell you the soloution its the digital board has a chip on there that needs to be cleaned or soldered directly to the board for the problem to be sorted for good
NAME: POPOOLA SAMUEL OKE
EMAIL:[email protected]
open the system and remove the cables (white cable) that are installed on the panel at the right hand-side.Replace the dettach cables after 10minutes,couple the system back and insert your cd.
i am sure it will work fine.
nb: the white cables are about 5cables at different location on the panel.
