Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
I have no installation cd and trying to install i downloaded a driver and it still doesn't work... what should i do
  • Kandi Cook Nov 10, 2010
    What operating system are you using on your computer? Windows vista? Windows Xp?
    Some printers will not work with Vista, no matter which driver you try and use.
    Please answer my questions as listed above and I will help you solve this. You can answer by going back to your original question posted on the website and using the reply and/or comments button.
    Master:
  • 397 Answers
One of the things I've experienced with the Lexmark drivers is if you have a multiple-core or laptop processor, the drivers may not install correctly-
One solution I got from the Lexmark Support team (mind this was a few years ago, so this may not work!)
In Product.INI- edit the info under system requirement to the following:
[System_Requirement]
Memory=0080,0080,0200
ProcessorSpeed=0000,0000,0000
DiskSpace=01F4,01F4,01F4
Good Luck!
Posted on Nov 10, 2010
After installing windows 7 my cd drive doesn't work. I've tried new drivers and disabling it and everything else I can think of... can anyone help?
Are you sure that you have installed the correct driver? Try going to the website of your computer's manufacturer and get the driver from there.
David
Mar 26, 2013 | Dell Inspiron 1525 Notebook
Downloaded gigabyte drivers to cd. can't get them installed to motherboard.
If you look in the files on the cd you will find a "Setup" file it will come up as an application. Double click this and the drivers should install to your computer. In the event this doesn't work you might try "DriverPack Solutions" it is a free program that finds and installs the drivers required by your computers hardware. It is a large file though and tou will need to save it to a DVD or a 4GB USB stick. Good luck.
May 28, 2012 | Gigabyte Computers & Internet
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
Computer does not recognize cd/dvd combo TSST Corp SH-S182D have yellow mark by device in Device Manager appears the driver was lost
Your device may be damaged, but here are some things you can try.
Go to the Device manager and right click your CD/DVD drive and select remove / delete. Now download this VB script and run it. (You may have to right click it once downloaded and select run as administrator if using Vista /Win 7) Restore CD/DVD in Explorer
Now reboot your PC.
If that doesn't work you may also try unplugging the device physically and replug it in, using another SATA/IDE/USB port.
Regards, Chris
Aug 12, 2011 | Computers & Internet
I have a HP all in one printer ( 4215 ) that doesn't want to scan anymore. Every time i try to scan it tell me that i do not have the right drivers. Before I change from windows exployer7 to windows...
I think your printer has actually lost it's scanner driver, might it's corrupt or it could be some other issues. The only solution is re-installing the driver. If you still have the Hp Driver CD that came with the printer, install all the drivers using the CD or if you don't have that CD, you can still download it from the HP Official website. Click HERE for Windows XP driver and HERE for Windows Vista. For Windows 7 upgrade, you have to install the software patch, click HERE to download.
If you need further help. Let me know.
Good Luck.
Thanks for using FixYa.
Jul 17, 2011 | Computers & Internet
Recently i have installed XP professional on HP Pavillion DV6830US. All the installations went ok. on desktop if i right click and choose refresh then screen is will blink/flash and comes back to normal....
You should have the CD for the devices of your PC. After installation of the OS, you need to install your devices' drivers using that utility CD. If it doesn't came with a CD or it came with a WIN7 utility CD which is not compatible with XP, you need to download it from the internet.
What you have detailed above is an indication that you have not installed your Display Driver yet. If you have already installed your devices and came across with this problem, try uninstalling your Display Driver and install it again.
Jun 08, 2011 | HP Pavilion dv6830US Notebook
When i load a game or a video my scree starts getting lines in it and shaking i think its my n460gtx cyclone gragpics card how do i fix
If you have the installation CD, you may want to uninstall software and re-install then, after re-installing from CD, update your graphics driver here;
http://www.nvidia.com/Download/index.aspx?lang=en-us
I don't really know if you can get all the bells and whistles for your card at MSI, because I've personally never used it but, you could use the "live eye" and see what they recommend here;
http://www.msi.com/service/download/
If the card is installed prorerly, and has worked well in the past, you probably just have to upgrade the driver. Try MSI and id they don't offer a driver or, if it doesn't work for you, try Nvidia's link. For best results, you should uninstall the old driver before download and install of new.
May 22, 2011 | MSI N460GTX Cyclone 768D5OC GeForce GTX...
My web cam doesn't work and i lost the cd for installion
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 18, 2010 | A4tech PK-7ma Flexi Webcam
Audio drivers for LG laptop
My laptop doesn't have audio drivers and it rejects each and every audio driver that i try to install. can you please help download and install a new audio driver
Apr 03, 2008 | Computers & Internet
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
