Question about Palm Computers & Internet
!. when I press hotsync button on my handheld it comes up with following Unable to initiate hotsync operation because the port is in use by another application. What does that mean, how do I find out what port is being used by another application 2. File pdn 20.dll not found what does this mean. Would appriciate very much any help I can get from you. David Jackson
  • 10 more comments
  • djackson5 Nov 10, 2010
    Thanks for your answer. I did as you said and installed Palm desktop 4.1.4e but dosn;t seem to change anything. it stills come up about port being used. David
  • djackson5 Nov 12, 2010
    just received this reply. asking what palm is it. The Palm handheld is Tungsten t3 The Port I take it is one of the 2 inputs in from of my computer. I have it in the top one. is that what you mean. By the way can I pay the $9 extra which gives me a month of questions, which I think I might need to clear up this problem David Jackson
    You asked what kind of Palm I had. It is a handheld Palm Tungsten T3
    I tried what you said but it still dosnt work.
    Should I extend my account to include the 1 month to ask questions untill I can get this going?
    I await your anser Thanks a lot David Jackson
    Thanks for your response, I did as you said and removed the EBible for pocket PC and related subjects. I unpluged cradle and restarted computer but it still came up with Application failed because dll was not found.. what do you sluggest now. david Jackson
    Thanks again for your response. Again I removed the ebible programe. restarted tried the sync on the handheld but nothing, it came up with the same - the port is in use. I put the ebible programe on again and at the end it came up with the same - failed because rapl.dll was not found. I dont know what to do now. I thought I got it all removed, including another program called Godspeed and it also had a sync with it. But it still didnt make any difference. DAvid Jackson
  • djackson5 Nov 15, 2010
    back again, Can I continue to ask a ?.
    I went to my lap top and I was able to get the old handheld to work. But I got a replacment 2nd hand handheld just like my old one and thats the one that keeps saying unable to initiate hotsync because port is in use by another application Still I dont know what the other application is as I have done all the things you suggested. Please let me know if my time has run out and I will renew my time so as I can get to the bottom of this. David Jackson.
  • djackson5 Nov 16, 2010
    Thanks again for your comments, and suggestion to clear everything on the handheld. I did this, but it still came up with post is being used by another application.
    This handheld also when it is in sync mode ready to send or receive has this on the screen BT to motor TP280i
    Then -enter Phone # I dont know what all this means When I press sync button while the screen says all of this ---it comes up with cant get thru......... Await your words of wisdom. David Jackson
    = Have done what you suggested
    = Removed all to do with ebible and palmone
    = Restart
    = tryed handheld (but no change "port is in use"
    = Downloaded Palm desktop 4.1.4e from palm support. It Asked me to sync but came up with "port in use'
    = Dont know where to go now
    = I also uninstalled all on handheld but nothing has changed
    =. on the hotsync in handheld it says AT&T worldNet Enter phone # what does all that mean, What is the phone #
    = What about your Tip "tune up utility" free 30 day trial would this help my computor?
    I sent a meassage thru with some of this in it but you Dont seem to have received it. Hopefully this will get through. Thanks a lot for your time and suggestions. Await you reply. David Jackson
  • djackson5 Nov 22, 2010
    I have sent several comments but received no reply, am I still on the same wave lenght with you?
    I did as you suggested. Removed all to do with ebible and palmone etec Restarted it but no change.
    Downloaded palm desktop etc again but still no change. Let me know if your still geting these questions Will await your word. Thanks David Jackson
  • djackson5 Nov 24, 2010
    I have sent another 2 or 3 questions but have received no answers. Is this comment getting thru? Please let me know if your getting this and I;ll send the questions. Thanks await your reply David Jackson
  • djackson5 Nov 25, 2010
    Tungsten T3 model #00V5ACW31BTB
  • djackson5 Dec 03, 2010
    Am still unable to get this thing working even though I have done what has been suggested. I have tried to get back to you on several occasions but no answer. Am not sure that this email is getting to you. Can you let me know if you are receiving this. I await your response. Thanks David Jackson
    President:
  • 1,566 Answers
Hello there,
Please do add the model and manufacturer so that the experts would be able to assist you faster.
I am looking forward to your response.
Thank you.
Posted on Nov 10, 2010
  • Palm Master
  • 13,433 Answers
Hello
PDN20.dll is part of the palm desktop, it looks like your palm desktop is corrupted, I'd recommend that you uninstall palm desktop and related programs entirely from the computer and then restart it.
run palmdesktop setup from the disc or find the correct one for your device from here
http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
If you still get the port is in use, make sure you turn off any related palm programs that might be running on the computer, made by palm or not, something might be trying to use the palm and preventing the sync, but the dll error definitely points to a corrupt installation and re-install should fix that.
What else to try? If you have another machine in the house install palm desktop there and see if it syncs there normally, if it does, then that confirms that something is going on on the other machine.
  • 4 more comments
  • Ekse Nov 10, 2010
    which palm is it? you might have the wrong port selected on the desktop program.
  • Ekse Nov 12, 2010
    Thats up to you - did you get the DLL error message to disappear at least?
    open up device manager, Right click on the computer or "my computer" from either your desktop or start menu, select manage.
    On the left side click on device manager.
    Now on the right, find the palm devices and related, right click and uninstall all of them, (if you get a checkbox about uninstall driver software? Click No, or leave it unchecked)
    then unplug the cardle and or the palm, then restart the computer.
    Once its started plug in and see if its working now.
  • Ekse Nov 12, 2010
    Did you do the device manager part of my solution?
    Also make sure you are actually uninstalling EVERYTHING related to the palm, the dll errors are coming up because you have not done so. or then this is another program thats giving you the error message.
    and repeat what I told you about device manager once more, you could even check the box that says delete driver software, and see if it helps.
    You must still have some program on the pc thats trying to use the palm.
  • Ekse Nov 12, 2010
    to confirm that the palm, and the hotsync actually work, you could try it on another machine that has not had palm desktop or related installed previously.
  • Ekse Nov 15, 2010
    Hey, no you haven't ran out of time. Theres no time limit.
    Do you have anything important on the handheld? I'd suggest you do a factory reset on it or a hard reset, that wipes it clean, back up anything important first of course.
    See if that solves the problem.
    Data Erasure instructions:::
    1 Open your Palm Tungsten T3 by sliding the bottom section away from the screen.
    2 Locate the reset button on the back of the hand-held. It will be a small circular hole near the center of the hand-held, revealed when you slide the bottom section away from the screen.
    3 Press the power button on the top panel of the Tungsten hand-held. Keep the power button held down.
    4 While holding down the power button, gently press and release the reset button using the tip of your stylus or an unfolded paper clip.
    5 Release the power button when the Palm Powered logo appears.
    6 A message will appear on the screen informing you that you will erase all of the data on your Tungsten hand-held. Press Up on the Navigator. This performs a hard reset, erasing all data.
  • Ekse Nov 25, 2010
    Sorry I had not received any comments since 10 days ago.
    Please read and follow the steps on this page
    If the problem remains its starting to sound like your replacement palm is faulty if it comes up, port is being used on more than one computer and the above instructions have not helped and you have performed a hard reset on the palm with the instructions posted earlier test it with another computer again.
    I'm not aware that your palm has any phone functions, I don't understand why it is asking anything about phone number or saying something that direction.
    As for the tune up utility? sorry I don't know I don't recall having recommended one to you for this problem.
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
Suddenly it will not take activity by screen. Pressing or drawwing on the screen gives NO results, as if screen is dead. Buttons still work. Just cannot add, change, or access entries. Can the database...
Welcome to Fixya
Sounds like the problem is the LCd screen already. Have you tried doing a hard reset to your palm? The data in your palm can only be transferred using Hotsync. Try uninstall/install the software again to the new computer. May i know the Windows OS of the new computer and what is the model of your Palm.
Thank you for using FIxya!
Sep 06, 2011 | Palm Zire 21 Handheld
Unsucessful hot sync
If this is still a prob..email me at bobzmailroom1@peoplepc.com there is a trick. Your prob is your pc
Aug 23, 2009 | Palm m515 Handheld
Palm tungsten 3 will not hotsync. b/c port is already in use.
A friend helped me fix the problem. Your site was advertised as free, but it was not. Shame, shame.
Aug 07, 2009 | Palm Electronics - Others
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Tungsten V
Re-arrange port configuration, install latest version of palm desktop. Right click on palmsync icon on system tray and check "Local Serial" . You may also use IrDa as alternate sync method
Apr 04, 2009 | Palm Tungsten E2 Handheld
I updated the Palm m130 to Z22. I lost all my addresses on the m130 whe installing the Z22. Is there anyway to retrieve the lost file?!
The solution to this problem is.. if the m130 still has all the data, then
you need to perform a custom hotsync to overwrite all files on the computer
  1. Click on the ‘Hotsync Manager’ icon and choose ‘Custom’.
  2. Highlight the ‘Datebook’ conduit and click ‘Change’.
  3. Select ‘Handheld overwrites desktop’ and click ‘OK’.
  4. Repeat these steps for the ‘Address’, ‘Todo’, ‘Memo’ and ‘System’ conduits.
  5. ‘Install’ and ‘Install Service Templates’ should be ‘Enabled’.
  6. Perform a ‘Hotsync’ operation by pressing the button on the Hotsync® Cradle, or Cable.
Now that the files are on your computer you need to sync them into the new palm
Same steps but this time Desktop Overwrites handheld
  3. Select ‘Desktop overwrites Handheld’ and click ‘OK’.
Oct 31, 2008 | Computers & Internet
Palm Zire 31 Synch stopped working
ideas:
Restart your computer,
Try a different data cable,
And last resort:
Give up on it.
(If you do give up, send it to me i need a new screen.)
Jul 07, 2008 | Palm Zire 31 Handheld
Can not find an available Com port for Hotsync
Right click on the Hotsync icon in the taskbar (usually at the bottom-right hand corner of the screen) and select "USB" sync, while unchecking "Serial" or "Com" options. Then, initiate the hotsync from your palm handheld, rather than computer. Hopefully this will help!
Oct 07, 2007 | Palm Tungsten E Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Computers & Internet Logo
139 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
