Question about HP Photosmart M22 Digital Camera
Need to reset camera - HP Photosmart M22 Digital Camera
  • acwoman May 11, 2010
    I have lost my owners manual and there is no reset button on my cam can you help
  • 983 Answers
There will be one option called reset in your cam just press that your cam will get reseted ...
Posted on Jun 17, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 17, 2008
    you can refer to the manual if you have any doubts .....
I need to reset the password it's been a while and i forgot it.Can you help me
I don't know what brand your IP camera system is. According to my experience of using Reolink's IP camera system:
1.If you want to reset the IP camera's password, normally, the camera has a reset button. Take my camera as an example:
need-reset-password-s-while-forgot-kn01uzg0poojzx3dnu2rqo55-2-0.png You press the reset button, then you can reset your IP camera's password.
2.If you want to reset your NVR/DVR's password, as far as I'm concerned, you can try pressing the reset key of NVR/DVR's mainboard for 10 seconds. Remember that don't open any menus. If everything goes fine, you will hear a sound of buzzer. Then you can reset your password of your NVR/DVR. I hope it could help you solve your problem.
If you have other IP camera problems, you can visit Reolink's forum, I got a lot of help there.
IP Camera Reolink Forum
Apr 22, 2016 | Home Security
Panasonic survelliance cameras - Need to reset
HOWTO: Factory Reset your Panasonic BL-C1/20
www.networkwebcams.co.uk/.../howto-factory-reset-your-panasonic-bl-...
Dec 12, 2007 - Howto guide for resetting Panasonic BL-C1 and BL-C20 back to factory ... CCTV camera icon ... Panasonic BL-C20 Factory Reset Aperture ...
[PDF]Operating Instructions - Panasonic
ftp://ftp.panasonic.com/.../Panasonic/.../security/.../WV-NF284...
Panasonic5. Preface. The network camera WV-NF284 is designed to operate using a PC on a network (10BASE- ... This function detects a motion in a designated surveillance area and issue an alarm signal is ..... Use this button to reset the settings of.
Quick Reference Guide for BL-C230 - Panasonic
Dec 05, 2015 | Panasonic BB-HCM311A Network Camera
I need to' reset The camera . How can i do ? Thanks
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
  • Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Aug 10, 2010 | Sony Cyber-shot DSC-W300 Digital Camera
I need a master reset, hard reset, firmware reset for my Nikon S710. I try with "erase all" but configuration is not equal to the first time use my camera. I need reset my camera. Thanks.
Two methods...scroll to "reset" in the setup menu and follow the on-screen instructions. -or- Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Sep 24, 2009 | Nikon COOLPIX S710 Digital Camera
I have a sony cybershot dsc-f707 Icant zoom in or out only after I take a picture. I also wanted to know if I need to charge the lense to zoom?
Option 1:
Reset the Camera and check if it helps to resolve the issue.(Resetting the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
The RESET button is located inside the battery/ Memory Stick cover. The Camera should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Use a fully charged Battery in the Camera so that the Zoom function work normally.
Aug 27, 2009 | Sony Cameras
My computer is not recognizing my L16 Nikon coolpix
I would suggest to resetting the camera. Each camera has a different procedure, but most cameras can be reset by removing the batteries for several minutes then replacing them and turning the camera back on. If that doesn't work, then read in your manual under "reset" or "initialize" camera.
Or you need to download the driver of the camera again...
Jul 01, 2009 | Nikon L16 silver Digital Camera
Master Reset Olympus x840
To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
Apr 13, 2009 | Olympus FE-210 Digital Camera
Need to factory reset E-Volt 500 Digital Olympus Camera
Put camera dial on P - go to Menu - camera 1 tab is highlighted - right arrow over to card setup - down arrow to custom reset setting - right arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera should now be in factory default settings
Dec 24, 2008 | Olympus EVOLT E-500 Digital Camera
Reset my camera vivicam 3710
The reset is not the camera, its the batteries. If you are using regular batteries its time for new ones. IF you are using rechargeable, then they either need to recharge, or have used their life expectance. Try putting in regular batteries and see if they work. If they do, you need a new rechargeable cell. Please let me know if this works for you! Thanks //D
Sep 29, 2007 | Vivitar ViviCam 3710 Digital Camera
HP Photosmart M22 Digital Camera Logo
241 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
