Question about LG WM-2277HW Front Load Washer
No power. the cycle stopped with water in the drum (i had set a delay). no lights, bells, nothing! I checked the outlet and there is power.
  • 320 Answers
Open the back cover and locate the fuse which is installed in side of the plug. Remove it from its plastic insulator and replace it with the same amperage and value.
Posted on Nov 10, 2010
  • borjie1 Nov 10, 2010
    Thank you Wiz, I'll give it a try!
  • roychristine Mar 20, 2011
    where is the fuse? pictures? part number? HELP???
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Stopped during cycle,water still in drum set to STOP and the light comes on,try anything else and nothing works
open the back and check 1 the belts are still intact 2 the pump is not working
Feb 27, 2013 | Washing Machines
Turned of packard bell pc,,, now when i press startup button itt wont start.. no lights .. nothing .. have checked fuses and changed battery in pc,,, still nothing,,, can you help?
Check power cord, check power outlet, check powersupply, check the 120/240 volt switch in the back... set it to the correct position...
Apr 09, 2011 | Computers & Internet
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint , no power, full of water
Turn off the water supply to the machine
Take the drain hose off the back of the machine and drop it into a bucket , you will need to do this several times.(Take off any clips that stop it from being laid flat on the floor)
Once all of the water is out of the machine try powering it up again, if it lights up do a spin to get the clothes dry , leaving the outlet hose in the bucket.
If that works then once the machine is dry try turning on the water supply with the machine turned off , if water runs into the machine then you have a faulty fill valve.
If that is ok then check the pressure switch and Air Bell which sits on the back of the main drum you could have a soap ball in the Air Bell which will false out the machine and cause overfilling
If there is no power check the mains supply to the wall outlet then the plug top wiring and any fuse fitted inside the plug top
After that it is down to a man with a test meter
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Whirlpool duet has no power
Is the power cord plugged into a grounded 3 prong outlet?
Plug power cord into a grounded 3 prong outlet.
Are you using an extension cord?
Do not use an extension cord.
Has a household fuse blown, or has a circuit breaker tripped?
Check to see if a household circuit breaker or Ground Fault Circuit Interrupter (GFCI) outlet has tripped. If so, reset the circuit breaker or Ground Fault Circuit Interrupter. If the washer is on a fuse box, check to see if a fuse has blown and replace it, if necessary. If the problem continues to occur, call an electrician.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not operate properly with only one incoming source of water.
Is the water inlet hose kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove the inlet hoses from the washer. Remove any accumulated film or particles. Reinstall hoses, turn on water and check for leaks.
Is the washer in a normal pause in the cycle?
The washer pauses for about 2 minutes during certain cycles. Allow the cycle to continue. Some cycles feature periods of tumbling and soaking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look closed, but may not be latched. Open the door and close firmly.
Are the shipping bolts removed?
All four shipping bolts must be removed from the rear of the washer before you operate the washer. Each unit is shipped from the factory with four bolts, which are designed to protect the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration, error codes and possible machine damage.
Has a cycle been selected, but Start has not been selected and held for 1 second?
Press and hold Start for 1 second.
Is the Control Locked status light on?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Is the Delay Wash status light on?
Your washer will start after the selected hours of delay are completed.
Was the door left closed after the last cycle?
The washer door must be opened and closed again to start a new cycle. If the door is not opened between cycles, the washer may not start.
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WD61 stops near start of wash cycle
all in the timer. but there may be nothing wrong. sometimes in the cycle there will be a gap between water full and agitate or between drain and spin depending on settings. try it again and let it go and if there is a gap of more than 5 minutes than it needs a timer. most machines timers are right around $75 and you can most likely replace it yourself. sears appliance parts is the place to buy it. you can order it and they will deliver it to your door. or if you can get the phone # most of the outlets have a parts dept. also they take parts back for full credit for any reason.
Mar 05, 2008 | Hotpoint WD62 Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
469 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Mike
Mike
reliableservice
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
