Question about Sony Cyber-Shot DSC-S40 Digital Camera
When i turn it on it saids to turn the power off and on again. i do it but it said the sae thing aqain. what to i do?
  • 455 Answers
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Good Luck!!
KenSolutions
FixYa
Posted on Nov 10, 2010
LX. should I use 5w 30 or 10w 30 oil?
lost the operators guide? in the glove box.
katrina, what part of country,?
Key West or Alaska.? (the -4f rule is clear)
the opr. guide explains all that... by climate.
page 5-8 in fact does that.
ill post it now.
and the words.
"• SAE 5W-30
As shown in the viscosity chart, SAE
5W-30 is the only viscosity grade recommended
for your vehicle. However, if it's
going to be -4°F (-20°C) or above and
SAE 5W-30 is not available, you may use
SAE 10W-30.
These numbers on an oil container show
its viscosity, or thickness. Do not use
other viscosity oil such as SAE 10W-40
or SAE 20W-50 under any conditions."
25916713-lx3lfdsu0gl5simxdk0r4o1e-5-0.jpg buy the guide and not get stranded for simple things ?
Oct 20, 2015 | 2004 Suzuki Forenza
Instructions on changing bulb
Turn off the projector, unplug the AC power cord, let it cool for 45 minutes.
remove the screw that holds the lamp cover on.
remove the 2 screws that hold the lamp in. lift the lamp out by the handle.
replace with new lamp and do the reverse.
reset the lamp counter.
press the menu button.
go to setting menu, then to lamp counter, press select button, select reset, select YES. then YES aqain.
Apr 06, 2011 | Sanyo PLC-XT25 LCD Projector
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
What type of oil do I use 1850 pm0401850
Oil Type. Use new good quality oil such as SC, SD, and
SE grades. The oil to be used depends upon the temperature
at which the engine is operated:
Summer: (temperatures of over 40 degrees F/10 degrees
C) SAE 30 or SAE 10W-30, SAE 10W-40
Winter: (temperatures of below 40 degrees F/10 degrees
C) SAE 20 or SAE 10W-30
Manual here:
http://www.powermate.com/pdfs/2007/11/12/pm0401850-52.pdf
Sep 12, 2010 | Coleman Powermate Powermate 5000W...
Steam smells odd and affects milk taste.
The boiler is contaminated with milk and needs to be descaled and cleaned.
Jul 31, 2010 | Astoria Argenta SAE-2 Espresso Machine
Samsung sgh/d900 message problem
Service centre number depends on the network provider you are using.
You can call their customer care and get the service centre number free of cost.
Then go to messages menu --> Settings-->Message centre number.
Here type your new number given from customer department and select it.
Switch off the mobile and then TURN ON it aqain.
Its all set to be used again without any problem..
Jan 04, 2010 | Samsung SGH-D900 Cellular Phone
Transmission
Its the transmission control model. it is malfunctioning and it will need to be replaced.
This module initiates the shifting signal that is then carried out by the shift solenoids in the transmission case. replacing the module will fix the issue.
May 09, 2009 | 2001 Ford F350 Super Duty SuperCab
Grade of oil
You should, of course, read the manual and use whatever the Kawasaki company recommends. That said, most small air cooled engines will do very well using SAE 30 detergent motor oil. Look for 5W30 at the auto parts store.
Apr 20, 2009 | Electrical Supplies
Wont erase messages
This happens a lot. I had an EnV and now an EnV2 and both phones did the same thing. For me, simply turning the power off and then on again on the phone made it possible to erase things again. If it still doesn't work, you may want to just take it into the store. However, I've had luck every time so far with just turning the power off and on like I said.
Dec 20, 2008 | LG enV VX9900 Cellular Phone
Sony DSC-W55 problems...Says Access and then restart..
Just kick it few times on the left side of the camera and the problem will be gone. Same thing happened to me and it worked.
Jan 02, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
135 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
