Question about Microsoft Zune JS8-00001 Digital Media Player
Broken lock switch zune Pink
The lock button on the top broke off and now it is permanently locked. Help?
  • 2 more comments
  • yaboililb31 Jul 07, 2008
    The lock is broken, its like easy to turn it on lock because I think the switch got loose and now it's permantly on lock.
  • Anonymous Jul 12, 2008
    same thing.........I didn't even realized it was broken. Should I just throw it away??
  • Anonymous Nov 02, 2008
    just wanted to state that after reading the post i decided to go rough with the lock button. It worked!!!! thank god i have my zune back....
  • Anonymous May 23, 2009
    I have a 80gb zune. and my lock button became brokin, but it still worked perfectly as long as it did not come off. Now it does'nt work at all.
    AN iPod WOULD NEVER DO THIS!!!
  • 846 Answers
Here is an Zune Repair Guide that shows how to open the Zune yourself. Hopefully you will find the plastic piece that is missing so you can reattach it to your switch, otherwise it's better to move the switch to permantly unlocked so you can at least use your Zune. You can also solder a bridge over the switch to make it permanently unlocked if the switch is broken (just put a wire that connects all the pins at the bottom of the switch together).
Posted on Mar 12, 2009
My zune lock switch completely broke off in the locked position. I used a paper clip to remove the small plastic tray under where the switch use to be. It came off pretty easily. Then I could see a small black toggle switch can I was able to flick it in the unlock position.
Posted on Feb 15, 2009
Followed Bhav91's advice and randomly moved a paper clip under where the switch was supposed to be for about 5 minutes, when the zune woke up auto-magically from it's locked state. I put some scotch tape on top to prevent it from slipping back again. Lets see for how long this works.
Posted on Jul 23, 2009
The guides in sllano2845 comments are definitely worth checking out. When I opened mine up I found out that that one of the pieces of silver tape shielding tape that's on top of the lock switch had somehow come off. To removed the strip of silver tape that ran from the zune's hard drive to the switch, span it round 180 degrees and stuck it back down. This seems to have improved connectivity. I also used a couple of pieces of insulating tape to make sure it was stuck to the hard drive. Phew! At least I don't have to shell out for a new one just yet.
Posted on May 13, 2009
    Problem Solver:
  • 9 Answers
I don't know what to do if it's completely broke off, but read how I fixed mine. Maybe it will help. There's also someone who fixed theirs by opening it up. I haven't tried it, but the said there's a video on youtube showing how to do it.
http://www.fixya.com/support/t1371647-unlock_zune
Posted on Dec 15, 2008
  • 8,596 Answers
Go ahead and call Zune, because that part is not repairable - you must repalce the entire player:
http://www.zune.net/en-us/support/usersguide/default.htm
Posted on Jul 06, 2008
Nokia E6 Unlock/Lock button on the side broke 4 times. Any permanent remedy?
hey can you say me where did you got it replaced ?? how much did it cost ?? even mine got broken and there is no where to replace it thanks, ravin
Aug 01, 2012 | Nokia E6 artphone
ZUNE LOCKING SWITCH
Well I guess I'll be using it too on the new Zunes because I think they are going to be a lot more sensitive with the touchpad
Mar 01, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune does nothing! Screen says Zune with loading logo but...
Let it on and completely drain the power, then try it. Make sure your lock key is not locked either. (at the top of Zune Device)
Jul 15, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune 30 gb broken "lock" button
The Lock button came right out and the wires attached to it broke, right? If so, y'alls pfft.
or, if not...
Go to this website and follow Steps 1 thru 4 ONLY. Picture 4 of Step 4 shows the top of the device to the left and the headphone jack nearest you. The Lock button should be right below the top arrow on the left of Picture 4. To unlock it, slide the switch **away** from the headphone jack.
!!! Please note that this is all strictly assumptions on my part. I have *never* taken my 30gig apart and am strictly working from the pics & past experience w/ micro-electronics. Do Not Take My Words As Being Absolutely Correct !!!
Mar 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune lock
Zune lock is the switch at the top of the zune correct? Slide it into unlock position.
If it's passworded and you can't get it unlocked
try this:
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 04, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune Hold Button broke
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Step 1 thru 4. Picture 4 shows where the Hold switch is right below the top arrow on the left hand side. Look see if it is broke. If not, re-assemble vewy vewy kehfewy.
These folks also do repairs.
*** I do NOT recommend or endorse that website! It just looks like they are more on the ball than Msoft.
Nov 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune lock and unlock button broke
I fixed mine without opening it up. Read what I did and see if it may help first.
Aug 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
Lock switch
You could try opening it up and checking to see if anything inside is loose or broken around the lock switch area at the top.
here is how you open your zune:
May 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
2,971 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
