Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Describe how to use the garbage disposer- currently it doesnot work- humming sound, no grinding
    Genius:
  • 1,015 Answers
Look on the bottom of garbage dosposal in the center you will see a allen type fiitting. I believe it takes a 5/16 inch allen wrench to fit it.Insert proper size allen wrench and turn it manually back and forth. It sounds to me like you have something in there that that is not allowing it to turn. By using the allen wrench to turn impeller you should be ably to free it up.Sometimes it helps to run very hot water thru it as you are trying to frree it up. If you can get it turning freely with wrench remove wrench and turn disposal on. If it still is not free try above procedure again. If it trys to start and stops buzzimg look closely at bottom of disposal there will be a small red button. This is a reset switch. Push it in and continue trying to free blockage. Hope this helps you. Thanks
Posted on Nov 10, 2010
  • avmonkey Dec 30, 2010
    I was on the way to buy a new one. Luckily I found this site and used the allen wrench, which on my badger was 1/4, to break up some broken glass and it works flawlessly again!!!!
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
My garbage disposal is not working. it "hums", but doesn't grind, and water drains slowly. there is nothing stuck in it.
You are going to have to try to push it through the stuck point. It is clogged without a doubt. Could be a piece of silverware in there. Use a flashlight and take a look down in the hole. Do not stick your hand in there but you can use a pliers or something to dislodge it.
May 16, 2016 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Titan garbage disposal 3/4 T960 series. The
Loosen cutter blade with boomstick handle
Otherwise, replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 26, 2014 | Electrical Supplies
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
Mar 23, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Badger 1/2 HP garbage disposal not working. Motor hums, blades are not rotating. I can rotate the service wrench with tension.
I would keep working the impeller back and forth with wrench while running hot water thru disposal until it turns freely. You can see if there are any small bone fragments or other debris in grinding chamber and removing with long needle nose pliers. Good luck. Thank you.
Apr 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My bager 5 seems locked up when you hit the switch it hums how do I get it unlocked.
One day years ago, our new garbage disposal got stuck, and started humming instead of grinding. My mom turned off the switch, then she grabbed a wood-handled broom and stuck it down in the disposal. I was wondering, what's that lady doing.
She took the wood handled broom and placed it on the disposal cutter wheel that was stuck. Then she wedged the broom against the sink opening, She pushed the cutter wheel forward until it was free. Then she showed me that the cutter wheel is supposed to spin freely even when the switch is off.
That's how I learned to un-stick a garbage disposal.
Oct 24, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
277 people viewed this question
Top Ace Hardware Electrical Supplies Experts
Craig Butler
Craig Butler
Mike
Steve Allison
Steve Allison
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
