Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer has been stored for about 3 years. It is not coming on, though all the buttons seem to be working
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Whirlpool Cabrio Dryer moisture sensor not working
The moisture sensor may be contaminated with softener residue. The residue can be removed with window cleaner ONLY.
Feb 01, 2018 | Dryers
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Dryer will not fire. Fuse is good and door swithch seems to be good. When you push the button in to turn on nothing happens. Dryer is just over a year old. Any suggestions.
then it must be either in the switch or the motor has burned out is the heating coil heating though the barrel isnt turning ??
Feb 15, 2011 | Estate EED4400WQ Dryer
I keep getting an F40 code on my dryer. I unplug the dryer and plug it back in and then it will run - but now the heat is not coming on in the dryer. I am so frustrated. This dryer is only 3 1/2 years old.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 19, 2010 | Kenmore 67082 Electric Dryer
Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Jan 30, 2009 | Kenmore 67082 Electric Dryer
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Jan 18, 2009 | Maytag MAV3905EWW 13 Cycle Washer
Wet clothes take two 'trips' to dry.
UNPLUG THE DRYER THEN PRESS THE MORE TIME , AND THE LESS TIME BUTTONS AND THE POWER BUTTON FOR ABOUT 10 SECONDS. THEN WAIT FOR 3-5 MINUTES THEN PLUG THE DRYER BACK UP . SEE IF THAT WORKS BY THAT RESET.
Dec 01, 2008 | LG DLE2514 Electric Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
