I have a floor model Motorola TV -- probably purchased in late 1950s-- How do I get someone to remove the picture tube, guts of the TV. I want to keep the cabinet.
    Guru:
  • 2,178 Answers
Take it in to a TV repair shop and have them do it for you. The tube could implode if handled incorrectly.
Posted on Nov 10, 2010
Where do I locate the picture tube in the tv and replace it?
there is no tube,it has different components and to fix them is going to cost you more than a flat screen tv
Jun 14, 2015 | RCA Televison & Video
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Replacement of the green lamp(picture tube) in a Mitsubishi 55'' rear projection HD TV. Lamp is out. Other two (red & blue lamps are fine.) How to remove lamp/picture tube? Price and availibilty of...
You can probably purchase a smilar set on Craig's list for $300.00, at least that's what they go for in the Austin Texas area.
A new tube may be too expensive and difficult to replace.
Sep 13, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Magnavox 19 inch television floor sample tube went out
You'll need to pull out the warranty paperwork and see what it says about repairs. You'll likely need to present the proof of purchase for the warranty along with the machine, for Best Buy to start the process. To be certain you're doing it right, consult the warranty to see what to do. You can void your extended warranty if you take the machine to someone not certified to work on the machine.
Jul 01, 2008 | Philips Magnavox 27MS343S 27" TV
Jvc floor model Tv
I have a 54inch jvc floor model with no sound and it will show a picture then the picture goes out and power button flashes red, can this problem be fixed
Jun 06, 2008 | JVC AV-48WP74 48" Rear Projection...
TV weight
The trick to lifting Large TVs' is that they are very 'front' heavy, that is, most of the weight is in the picture tube...recall the "problem" of unstable TVs' from years ago (Children pulling down TVs')
If the TV is on the floor you can put a large pillow at the front (Picture tube face) on the floor & carefully tip the set forward onto the pillow. You can then measure the bottom of the set to see if it will fit on your stand. If you are concerned about the weight simply attempt to sit your body (180 lbs?) on your suspect stand..if it holds your weight your good...wiggle around to see how stable it is.
_________________________________________________Rick......
May 24, 2008 | Televison & Video
Change power cord on old Hamilton Beach Mixette
You have to unscrew screws at its bottom and strip away the plastic cover. Does it look like this from below?
http://bpics.rubylane.com/graphics/shops/starvingstudent/12.2L.jpg
Apr 09, 2008 | Food Mixers
Picture turns on and off
Just found this trying to figure out what was wrong with my same model tv. Since mine was under warantee, I had the repairman troubleshoot it. He changed the lamp and the tv started working normally again.
I didn't understand how the lamp could be bad if it lit up while the tv was on. He said the tube was probably using too much voltage or too little voltage to run, so the tv would turn itself off and on in an attempt to receive the correct voltage from the lamp.
I realize this is 9 months late, but maybe it can help someone else who has this problem. I can't believe there are only 3 rca dlp's out there with this problem.
Mar 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
