Question about LaCie (300770) 250 GB Hard Drive
Lacie drive runs when plugged into the computer but the icon no longer appears on desktop and drive is unavailable.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 10, 2010
I just plugged my LaCie hard drive into a PC with a USB cable (not sure of the name of the specific cable - it's the smallest, not firewire, USB on one end, a small circular end on the other that plugs...
Try a different USB jack. If it still doesn't appear you probably have to format it for Windows.
To do this, right-click on My Computer, go to Manage, then choose Disk Management.
The disk should appear there. You'll have to format it for Windows in order to use it.
Feb 01, 2011 | LaCie Computers & Internet
My Lacie hard drive worked perfectly for a period of time. I use it to make films and store all my files and final work on it. It now no longer appears on my desktop and I cannot access it in any way. ...
> it does NOT show on ... Macbook Pro running OS X 10.6.4
> it DOES mount up on older computers running older versions of OS X
> Lacie ... said there was no problem
So, the problem is "local" to ONE of your computers.
Be sure that your computer is connected to AC power, not running solely on its battery.
Try some other USB device in the USB port, to confirm that the USB port is working.
Nov 11, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Hard drive icon wont appear on desktop
Have a look in disk management for the drive.
Start > Run > type 'diskmgmt.msc'
If the drive is there and has a blue bar, try changing the drive letter.
If the drive is there, but has a black bar, you will need to recover your data with a recovery software (option - recuva recovery software) and then repartition the drive.
If the drive isn't there at all, you may need to try another USB port, another cable or even another computer.
If none of these options help, you may have to contact Lacie for your support options (possible replacement).
Jan 25, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
My Lacie driver is no longer acessable
you could send me it lol :)
When you say it gives you a blank window did you leave it for a while - I have to do that with my 500gb hard drive which has a lot of stuff on it and it takes a while to read what it needs to before it shows the files / folders
maybe a defrag if you can get it back up and running and also try it on a different usb port on the back of the same computer it was working on
May 16, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie HD won't open..no icon on desktop?
I have the same problem, it was working but just stopped for no reason, even tried new leads but still no joy.
Mar 09, 2009 | LaCie (300740) 160 GB Hard Drive
How to correct connection problem for two LaCie Desktop Hard Driv
Here is the support website for the LACIE products.  As far as I knowthis site simply answers questions. Sounds like the hard drives are bad to me.
http://www.lacie.com/support/
Jan 07, 2009 | LaCie Computers & Internet
Not showing up
recheck to insure partitions rexcognized and reinstall unit driver.
Jun 22, 2008 | LaCie Design by F. A. Porsche 80 GB Hard...
Lacie sounds like its working , but i can't find the icon on computer
Your hard dive is probably not formatted. You can check if your external hard drive is detected by the BIOS during bootup. You can also check this by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your lacie. If you dont then the drive is probably not detected. If you see, you can just partition it from here and it will appear in your my computer.
Dec 24, 2007 | LaCie (301015) 120 GB Hard Drive
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie (300770) 250 GB Hard Drive Logo
66 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
