HDD volume mis-reported by XP
Hi. You've probably been asked this loads of times, but at the risk of boring the pants off you, I will ask again!
I have just installed a new 250GB sata HDD. I used a XP (home) disc to format the HDD before installing XP and re-loading all my drivers, etc.
However, XP is only reporting the HDD size as being 127GB (ish) under both 'My Computer' and in DOS using the 'DIR/W' command.
Can this be fixed without reinstalling XP?
I would be most grateful for any advice you could give.
Regards, Roy Stothard
    Master:
    Sergeant:
  • 462 Answers
Well you need to check if there is any fault in the 250GB HDD for that there are 2 options one is connect it as external to ur pc and see the total disk size.. else take it to the service centre with your warranty...
Feel free to askmore...!!
Thankyou
Posted on Jun 17, 2008
Unmountable boot volume
get a copy of hirens and run HDD regenerator I think you have some bad sectors and a corrupted windows.
Feb 03, 2013 | Dell Latitude D410 Notebook
I replaced a new hdd and still showing 1720-smart hard drive detects imminent failure
There is a chance you received a new bad hard drive. I've seen this with server drives, but never at desktop level. I would not accept, but HP might ask you to do some testing or load an update. I forget. Good Luck replacing again
Aug 28, 2012 | HP KR646UAABA - Compaq dc5800 Microtower...
I installed a new WD 500GB hard drive in an HP Pavilion 513n as a master and have a 60 GB hard drive as a slave for backup data. Both are set to auto in the BIOS. Every time I turn the computer on even...
I think, in BIOS setting your first booting device is the 60GB HDD. change it to HDD0 as 1st boot, CD Drive as 2nd boot and HDD1 as third boot device and it would not ask any error report.
Aug 28, 2011 | HP Pavilion 513n (P9850A#ABA) PC Desktop
How to reinstell window xp .starting stage to finish
Insert Windows XP Disc
Boot from CD when prompted
Windows Will then Load Files
after loading it will come up with prompts.
One may be, Do you wish to repair if you see this press escape :)
then it will scan and bring up partitions (HDD's)
You should only have one. unless u have more than one hdd
select the "C:" and press D then Enter and L
Then Hit Enter it will ask if u wish to Quick Format or Format.
Select Quick (its faster)
then windows will install files, and reset.
when it boots up it will do its own thing for about 5 minutes (approx.)
then it will ask you for the CD Key, Name and Location, Network Preferences (only if it installed your device drivers).
Then it will ask for Time, probably not in that exact order.
then it will finish providing everything went good.
then will reset and you will have install all of your drivers and software.
Apr 13, 2010 | Dell Inspiron 1525 Laptop
Windows xp will not load
When it asks for administrator password, and you didn't have one set, just push enter and you'll be able to continue.
If you don't need any information from the computer, use a program to writes zeros to the drive and then you'll be able to install windows. HDD manufacturers provide a program to zero the drive
May 08, 2009 | Dell Latitude D600 Notebook
At start up my computer reboots 2 or 3 times
Hi there!
Try running on safe mode. Here's how you do that power on your PC press F5 continuously untill you see the boot menu and select safe mode. from there run the following: antivirus, checkdisk and spyware removal. hope it helps.
Mar 18, 2009 | Medion M3 Director 5100 PC Desktop
Hoe to install a diferent windows on a DELL
If HDD makes shshshsh.... or spinning sound or generates heat, your HDD might be ok. Next Try with XP sp2 cd. If it again cant detect HDD, go to BIOS setting and watch if the HDD is showing it's status. If Bios can not detect HDD check HDD cable and power cable inserted in HDD. Replace them if needed. Format the HDD with another PC. If you still have problem replace HDD with new one. One thing you might use your corrupted HDD as a slave drive later, i hope.
Keep informing.
Feb 23, 2009 | Dell XPS 600 PC Desktop
Dell c400 upgraded to xp now it won't boot up
you have toboot xp in the dell they are not interchangable you have load xp withit inthe dell or the dell wont work
sorry to be the bearer of bad news
Dec 21, 2008 | Dell AMD 386/33 Desktop Computer 333S/L...
How to get password from hdd password error code acer aspire 4315
Is the error message coming before bios starts to load XP from harddisk, or after?
If it is coming after XP starts then it may be driver issue.
If it is coming before XP, then it may be a question of incorrect bios for the hardware in your laptop.
Jul 27, 2008 | Acer Aspire 5500 5570-2609 Laptop
Whirlpool washer makes loud noise but aggitator doesn't even turn
a load of Jeans or pants is hardest on washing machines , you probably broke the belt for the aggitator
Dec 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
