Question about LaCie Photon20visionII 20.1" LCD Monitor
Won't turn on. Started turning itself off intermittently and then quit altogether. Have replaced power supply cord but this did not remedy the problem.
  • Kandi Cook Nov 10, 2010
    Are you sure that the new power cord is the right voltage and appropriate for use on your monitor? If you just kept trying old cords until you found one that fit the connection on the monitor, please check the voltage requirements listed on the back of the monitor itself and compare them with the voltage facts listed on the plug head of the cord or someone on the side of it. Sometimes the letters/numbers on the cord are hard to find and very small, but they have to be there.
    If you have checked the above, and found that the cord is appropriate and not the problem then continue below and answer my questions so that I can help you solve this problem.
    Sounds like it is over heating.
    Lets eliminate this possibility before we try and troubleshoot further ok?
    Unplug the monitor from the power source and disconnect it from your computer. Push the power button on and hold it for a few seconds to make sure no electricity is in it. Then get a can of air and blow the dust out of the vents on the monitor until your sure that there is no dirt or debris affecting the ventilitaion system. Then plug the power source back into the wall without connecting the monitor to the computer. Turn the monitor on. You should see a message that says something like "no video" for a while then it will go to black screen but a normal monitor should stay on and continue to remain connected with the power light on that is either red or green.
    Tell me if the monitor remains turned on or if it turns itself off. Give it a good five minutes or so.
    If it stays on, then turn it off and connect it back on to the computer and turn it on. Tell me if the problem is solved? If not, then tell me your findings through the comment section on the orignal post of your problem on this site and I will help you find a solution.
  • 11,361 Answers
More likley to have bad power supply due to bad caps, look for that first.
Please read my guide and learn about bad caps and failed monitors pictures.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 10, 2010
Have a sanyo 50" plasma
This tv problems are related to powering up the tv and sustancening the tv power source to the tv itself.Replaced the tv sub power supply board where the a/c power cord plug into it.Try website like Ebay.com to buy a whole new refurbish sub power supply board for the replacement.
Sep 06, 2011 | Sanyo DP50747 50 in. Plasma TV
TV randomly turns itself off and then comes right back on. Unfortunately it never does this during a commercial. Generally happens during a punchline or critical plot twist. WHY would it do this??
Tv power supply board is developing a problems.That the board where the power a/c cord plug into it.That why tv is have voltages glitches intermittently power shutdown unknown times.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 16, 2011 | Philips 42PFL7403D/27 42 in. LCD TV
It will no longer turn on...unplugged and replugged. Was having trouble turning on then quit altogether. Bought it a year ago at Walmart. 15" screen
Possible failure of the main power supply which is a Switch mode power supply. Unless you can remove power cord and check on the power section the fault cannot be confirmed.
check this link for some helpful tips :SMPS
Dec 24, 2010 | Televison & Video
My vizio plasma tv quit, Problem with the
Check ur power source with other devices?Yes.Than,the power supply board it dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 23, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
TV turns itself off
probably your tv is developing a intermittent problem by cutting off when it develops heat.this is a hard problem.but to remedy it you can make checks in the power supply and resolder the regulator or go to the flyback area and resolder all the legs or the horizontal output.or resoldder the entire power supply component.if that does not solve your problem.it is time to take your set to a tech good luck.
Feb 21, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
Heater fan doesn't blow
most likely the blower motor has gone out completly pull the harness off the blower motor and see if its getting power
Jan 15, 2009 | 1992 Honda Accord
Won't turn on
I bought two tvs and after about 3 months one of my tvs would not turn on; this tv was used more than the other one that is still working. I noticed that the power cord has a box that connects the two parts of the cords together, well the box gets very hot. I thought that the problem could be the power cord (may be it burned out) and not the tv. I switched power cords from the working tv to the nonworking tv and that sovled the problem.
Dec 17, 2007 | Proscan 19LA25Q 19 in. LCD Television
LaCie Photon20visionII 20.1" LCD Monitor Logo
104 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
