My torrent wont start whats wrong with it
Well, we kinda need a little more info to try and figure it out, but to make it easier, we'll start at the top. Got gas? Oil? Does it crank? If yes, does it have gas? If yes, is it going through the throttle body injector? Don't know? Try removing a spark plug and look at it and see if it is wet, oily, black, crud, You could plug the wire back to it and lay it on a piece of metal on the engine somewhere and have somebody crank it over, to see if it sparks. If yes, then squirt some fuel in the cylinder and put the plug in and see if it fires, OK, then, if it fires, we know the fuel pump is shot. If it doesn't, we need to find out what happened to the coil pack, ignitor, or whatever your car has for ignition system, backing up here, if it doesn't crank, skip all the above and get the battery fixed up, could be old, shot, dirty terminals, some cars had a shut off switch on the fuel pump if it was low on oil, some have a shut off switch if it hits something, gets towed, anything like that. OK, back to the coil pack, test the spark again, make sure you have spark, and clean plugs, new plugs won't hurt, plug wires will mess up an engine every time, Check it out, hope this helps somewhat.
