Question about Smith Corona Wordsmith 100 Typewriter
My processor is jam the carrier will not return
  • 73 Answers
Some models have a carrier lock. Look around the sides of the carrier for a blue lever that may be engaged.
Posted on Nov 28, 2010
When i press copy the carriage shoots across and
The slamming of the carrier past the forward stop cause a reported carrier jam.
You should have the printer serviced by an authorized Lexmark Servicer.
Don
Nov 19, 2009 | Lexmark P4350 All-In-One InkJet Printer
Carriage jam
Is it tasty? never had that type of jam!
If the ink carrier jambs then wipe the rails with a damp cloth to remove built up ink. Make sure power is off when you do this. Return power to the unit and ensure all cartridges are seated correctly. As you turn on the power the cartridge carrier unlocks and begins to move. quickly turn the power off at wall switch, and manually move the carriage to the left so you can clean the rails where the carriage rests. Then gently return the carriage to its resting spot and turn the power back on. This should now work correctly. Keep the rails clean and it shouldn't happen again. If this did not fix it it will need to be sent back to a repair shop
Please rate our help++++Thanks for using FIXYA
Sep 23, 2009 | HP Photosmart C4280 Aio Printer
Problem after clearing paper jam paper jam message still being displayed no other programmes functioning cartridge carrier will not return to cartridge change position
Restart your computer and power-cycle your printer off and back on.
Make sure the paper tray is not overloaded.
Make sure the paper in the tray firmly pushed into the paper tray towards the printer.
Jun 28, 2009 | Lexmark P4350 All-In-One InkJet Printer
What is a Carrier Jam?
You might have lost a little spring. Can you possibly return it to the store where you got it?
May 16, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
The ink carrier has a clear carrier jam message...
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, then its a hardware issue and you should contact Lexmark for replacement of the printer.
Apr 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Bobbin knots up
Clean the carrier area - just a small amount of lint can inhibit the seating of the bobbin's latch, which then jams during sewing.
Jul 12, 2008 | Brother LS-2125 Mechanical Sewing Machine
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Smith Corona Wordsmith 100 Typewriter Logo
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
