Question about Whirlpool Duet GHW9150P Front Load Washer
What is f 11 on my machine - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa !!
Posted on Nov 10, 2010
Serger Needles
Janome Overlockers (sergers) are set at the factory with #14 Red Tip needles
For finer fabrics, the #11 Blue Tip is good
If the #11 breaks, then try a #14 as they are a little heavier duty
You can always:
Contact Us at Bargain Box
Have a look at the detailed descriptions on these links
Accessories Parts
Apr 20, 2014 | Sewing Machines
Can a Schiller AT2 ECG paper size ( 8.5 * 11) inches be used on a GE MAC 1200 EKG machine?
hi,
Both machines uses the same dimension paper ( 8.5 * 11 Z fold paper ). You can use the paper in GE MAC 1200 EKG machine.
ok
Sep 27, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
There are 10 machines, which make pills .Each pill is10 g. Of these 1 machine is defective. It produces 11 g pill. You have a weighing machine, using this only once find which is defective,
Aug 16, 2010 | Computers & Internet
When sending fax on recievers end all the writing is downsized
Try sending a fax to someone else and see if it does the same thing.!
If your sending a 14" page to someone who only has 11" paper in the machine....the machine can only do one of 2 things...reduce the 14" page to fit on 11" paper "OR" print 11" on 1 page then the 3" on the second page....this setting is controlled by the rxing machine.
Apr 16, 2010 | Office Equipment & Supplies
Error code 11 on primus rs16
Error 11 is a water pressure or inlet problem. Check the 1st stage filters in the cold water hoses at the back of the machine.
Mar 03, 2010 | Washing Machines
11 minutes timer flashing, machine locked
unplug washer over night. plug in try drain and spin, if it works after finish try to restart. an 11 minute stall is likely error code f / 11 or dl code starts intermittently then goes out possible ccu board under top at rear
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Whirlpool Duet GHW9150P Front Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
