Question about Cell Phones
My home handset has 1 main base and 2 extra handsets with bases. it is less thtan a year old, and it crackles so much, I cannot understand anyone or anything. It does not matter how close to the base I am. I have tried to unplug and reset the phones but it has not worked. Anything I can do short of returning the product that I am not happy with?
    Master:
  • 397 Answers
Are you running a wireless internet connection in your house? do you have unshielded sub-woofers near your phone's base? The issue may be that you are getting interference from other devices- if the phone is on the 2.4 GHz band- see if there is a way to swap channels in that band. If not, see if you can swap channels for your wireless connection. Move the base to a room that does NOT have electrical devices near it- other than that- there is not much you can do other than find phones that do not utilize the 2.4 GHz spectrum. (it seems that almost all modern equipment emits in that spectrum for some reason...)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Posted on Nov 10, 2010
Simply can't register any of my 4 handsets with my BT Synergy 4100 cordless phone. All handsets indicate base is "unavailable" there isn't a fault on the line as I have tested it and I have gone over and...
Partial solution. The handsets may be registered to another base.
So go into handset setting, then select base, (select another base if there is one showing).
Then go through the handset registration procedure again.
D
Jun 20, 2009 | Cell Phones
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into...
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Aug 11, 2008 | Lands Phones
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
No intercom connection between handsets
Here is a link to the uniden manual link and an excerpt from the manual section which deals with your problem :
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
The handset doesn't
communicate with other
handsets.
• De-register the handset (see "De-register the Handset" on page 32) and register the handset
(see "Register the Handset" on page 68).
• Make sure that you have registered all handsets.
An extra handset can't join
the conversation.
• Make sure there are not 2 handsets already using the 3-way conference feature.
The handset or the base can't
join the conversation
• Make sure that another handset or base is in privacy mode.
To register a TCX805 handset, simply place it in the main base.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD.
When R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to
the base. If R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
To register a ELX500, TCX440, or TCX400 handset, follow the steps below:
1) Disconnect the AC adapter from the main base.
2) While pressing down flash/find hs, reconnect the AC adapter.
3) On the handset, press and hold # until you hear a beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
Dec 17, 2007 | Uniden TRU8885-2 Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
