Question about HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop
Doing nothing but i have tested the power suply and it is good
  • joecoolvette
    joecoolvette Nov 10, 2010
    1) How did you test the Power Supply? 2) Doing nothing meaning what? No power to the computer? (Power supply does not come on when you press the Power On button) Power to the computer as in LED lights light, fans spin, but No Signal to the monitor?
  • 1,179 Answers
I suggest going through my tip pertaining to this matter, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!! this should guide you through the process and get your PC going again.
Thanking you
damnor01
Posted on Nov 10, 2010
I have a toshiba 32av500u,
Do you have backlights or have you tried the flashlight test.
Feb 27, 2018 | Toshiba Televison & Video
I press the power button on the reciever and I hear a click and nothing else. The screen does not come on and nothing works.
Its most likely the power suply.. Would cost around $15.00 for get fixed.
Have a good day !
Oct 21, 2009 | Sony STR-DG520 Receiver
No power
Probalby the flybach power suply.. Get it tested to determine what has failed and if it is that it should cost around $200.00 to get it replaced..
Good luck
Sep 08, 2009 | Dynex Televison & Video
Sony 52inch projection nothing happens,timer light blinks all the
check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Jan 09, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a dell dimension 3000 pc that i haven't used for a few weeks as i was waiting for an external hard drive to put all my music, videos etc on. I have just come to use the pc and it won't even turn on....
if the external hard drive is hook up to the main drive you might have to disconnect the exteranl hard drive and try another way to hook them up together . you did something wrong when you installed the externall drive. try it . and see if the original hard drive boots up. if this works you will have to change the boot sequence to use the external drive.
Dec 01, 2008 | Computers & Internet
Doesnt turn on anymore.
Hi..there,
It's seems your backlight inverter is burnt out... need to be replaced with a new one or you can repaired yourself by testing all the capacitors to see which it has been burnt out or has a leaked. After that just replaced the bad caps... Good lucks, Have nice a day!
Aug 16, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
No Typing, but Powers Up, brother ax-25
open your typewriter and muve prinre left-rigt, you have a prnters jam or power suply module is not ok too low dc voltage
Jan 25, 2008 | Office Equipment & Supplies
Unhibernating
you have to start doing a test on secuences first you have to make sure the power from the outlet to the end the cable it has 120 v ac if there is power you have to open the case to check the power suply output to the motherboard there is a power suply testers you can get that on fry'z electronics store i think thats where your problem is located power suply after you do this test post it back to see if does not fix the problem if does fix it leave your feedback
Jan 01, 2008 | Computers & Internet
Dont Post
I thunk your rite it met its maker, sounds like you followed all the test procedures, and unfortanuly that's what happens from time to time working great on min then gone to the GB in the sky the next. unless you have a DX card or know someone that has one, (and thats only to confirm its dead) sounds like you need a new system board.
Nov 20, 2006 | Acer AOpen AX4BS-V (91.89J11.001)...
HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
