Rinnai Econoheat 850 gas heater
Hi there
I have a Rinnai gas heater at my home that I am having problems with. When you first light it, it runs fine for 2 or 3 minutes but then goes out. Sometimes i can get it started again and it does the same thing, but sometimes there is no chance of getting it started. There is plenty of gas available, the only problem is that it won't stay lit for over 5 minutes.
Regards
Daryl
  • verdaan May 23, 2009
    I have econostat Rinnai gas heater and pilot flame stays only for 30 seconds and goes off. I have no idea what is the problem. The gas is from the main line.
    Scholar:
  • 41 Answers
Hi Daryl,
It needs a service. The jets carbon up and when they heat up they stop the gas getting through. If you take it to a Gas Shop they will charge you around 90-00 to service it and all they will do is blow it out with compressed air. If you can get hold of an Air Compressor with an Air Blower on the end you can blow it out yourself. Remove the Gas Hose from the back and place the Air Blower into the hole where the gas goes through and hold down the ignitor switch to open up the jets. Give it a good blow out. Once you have done that give the candles a blow as they eget dirty also. You will see a white dust more than likely come out of them. If you want to give it a good clean out remove the cowling and clean (blow out) the inside of the Heater. The cowling from memory has only about 6 or 8 screws holding it on. That should take the top and sides off. I can't remember if you can remove the lower vent on that model - if so it will only be either 2 or 4 screws. Hope this Helps.
Regards
Bryan
Posted on Jun 21, 2008
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
Is there any possibility my Rinnai econoheat850 gas heater can give off carbon monoxide?
Any time there is combustion of any type fuel, from a Rinnai heater to a car engine. There is always a small amount of Carbon Monoxide given off. But, it's usually in small insignificant amounts.
Since your model is a Vent-free or flue-less model, the chances are a little higher. This usually occurs if the heater has not been properly and regularly maintained. Keep in mind, flue-less heaters take in household air for combustion, heat it and send it back out. Whatever is floating in the household air (duct, lint, pet hair, etc) is pulled into the heater. These things can clog the burner(s), the pilot and the Oxygen Depletion Sensor (ODS) and cause incomplete combustion. Which translates into higher than normal Co levels. However, your unit is equipped with an ODS, that will shut the gas off to the heater, if the household oxygen level reaches 25%. Which is not the danger level, which is 19%. Once the Oxygen level returns to 30%, the ODS will release the gas valve and gas will return to the pilot, so that you can relight it.
When properly maintained and operated according to the Owners Manual (see link below) they are totally safe. In the last 20 years, millions of vent-free/flue-less heaters have been sold and operated throughout the world. There has never been a death related to their use.
Certainly, if you or your family think you are experiencing signs of carbon monoxide poisoning, stop using the heater and have a qualified Rinnai technician check and service the heater. If you have other gas appliances in the house, it may be one of them causing the symptoms and not the heater. You may want to have those check and serviced, too.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Cosyglow&Econoheat.pdf
I hope I was able to help you. Please let me know. Thanks.
May 11, 2011 | Rinnai Heating & Cooling
Need pilot light assembly for Rinnai gas heater model #REH-25-P
Unfortunately, Rinnai only sells repair parts through their authorized dealers. Contact the dealer you purchased it from. If you are not the original owner of the home/heater, you can go to Rinnai's website and search for a dealer near you. http://www.rinnai.us/direct-vent-wall-furnaces/
Feb 28, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
What causes a diffrence in glow colour?
Normally purple/blue on the radiants indicates low gas pressure, could also be dust slowing gas velocity into burner and/or an aeration problem. Get it checked out properly.
Jul 07, 2009 | Heating & Cooling
Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
Jun 01, 2009 | Rinnai Vent Free Gas Heater/
Set gas pressure for lp space heater
the change over would be in the jets and air shroud positions to get the correct burn
talk with a gas fitter as to the regulator settings but if you used the correct jets , the pressure regulation will be that same as it is the jet size that influences the flow rate of a regulator
That is why it is called a regulator and not a tap
Nov 02, 2017 | Goodman GMS80903BNA Heater
Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
May 16, 2009 | Rinnai Heating & Cooling
Rinnai econoheat 850
sounds like it has a faulty button. The "on" button on that model has a button on the front side which should hold the on button down after igniting. Check and make sure that it is there. I think it is a spring loaded button - maybe the spring has dis-lodged itself. If the button is faulty yhou can only replace it.
Hope this Helps
Regards
Bryan
May 15, 2009 | Heating & Cooling
Using the rinnie as a major heating source for an older home
The smaller the vent the better. A Rinnai may heat an area just fine but a whole house is pushing it.
Dec 17, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
2,460 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
