Question about LG Heat cool Window Air Conditioner
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
  • Robert Moller
    Robert Moller Nov 10, 2010
    Does the fan turn ?
  • 81 Answers
So the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Posted on Nov 10, 2010
The unit turns on but why doesn't the fan?
Please reply with whether the unit is set to heat or cool mode?
If on heating, the inside coil has to get to temperature before the fan will start
Good luck
Jan 05, 2016 | Heating & Cooling
Heat Pump makes a surging/buzzing sound every 20 seconds
You might have a short going to your reversing valve. Check the temperature of all three lines out of the valve. The one on the left should be cold and the one on the left should be warm hot. . Check voltage to the valve.if it fluctuates that might be the reason for the buzz.
Mar 04, 2015 | Heating & Cooling
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Condenser won't kick on, and is hot. Fan works? What's should I do?
Check whether the AC is on fan mode. There are two mode for this type. FAN and AC mode. Put it to AC mode and set the temperature. Solved!! :)
If it doesn't work, call the AC repair guy.
1) Either there will be error with the capacitor circuit which triggers the condenser.
2) there is an issue with your condenser and the circuit.
This is a small repair.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Replaced relay, but both electric fans won't come on
Are we talking about the cooling fans for the engine and AC condenser?? Only one cooling fan will cycle on and off during normal operation. The main cooling fan will cycle on and off as needed for cooling the engine. If you turn on the AC or select a defrost mode on your climate control then the 2nd additional fan will run usually continuously in order to condense the freon in your AC system for cooling the interior of your car and in defrost mode it helps to reduce interior moisture on the glass (defog/ defrost). If no fan comes on at any time whether the engine is hot or cold or whether you turn on the AC or not and you have already replaced a cooling fan relay and checked related fuses then either the fan /s are bad or you dont have power in or out of the fan circuit which consists of several components that would need to be checked. Let us know if you find anything else or have additional questions.
Apr 25, 2009 | Hyundai Motor 2000 Tiburon
I have Goodman combination heating and cooling outdoor unit PBB series. I am wanting to know if when the heat is on should the fan outside turn or is that only ac
If it's a heatpump, then yes the outdoor fan will turn unless the unit is going in defrost mode. But for the majority of the time a heat pump is operating in heat mode, the outdoor fan is running.
Jan 16, 2009 | Heating & Cooling
Honeywell thermostat
make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
LG Heat cool Window Air Conditioner Logo
211 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
