Back to:
Tags:
JVC AV-48P575 48 in. Rear Projection HDTV-Ready Television
Help (by 2 users)
posted by jaimeg on Jun 17, 2008
my tv made a poping nosie now will not turn on
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Sep 03, 2008
Ours just did the same thing, made a pop and then went dead and will not turn on at all. Where do you get the fuse at?
Solution #1
posted on Jun 17, 2008
Not Rated (0)
jaimeg
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
open the back panel replaced in line fuse
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on help:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
Hello, I've had a GE 46GW948 TV for 7 years, it worked...
JVC AV-48P575 48 in. Rear Projection...
over time my screen has a burnt image in it and needs to...
The television picture has a green tint after the...
My JVC tv is only 2 years old. It has very little hours on...
If it's a transmitting signal, why doesn't it happen on my...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
