Fires up and runs for about 10 seconds then shuts down,gave error code of 1F not sure what that means.
  • 81 Answers
What type and brand is your unit?
Posted on Nov 10, 2010
OK, I changed/adjusted the TPS on my 86 Cadillac. The car will start and run for about 20sec then shut off. Im getting error codes E22, E26, E52 and F32. Does anyone know what is wrong now?
Very likely it could be a crankshaft position sensor if you can fire it up and runs for 20 seconds and shuts down it could be your problem which if that is one of the error codes after a scan it can trigger other codes with that one faulty sensor
Jan 20, 2017 | Cadillac Cars & Trucks
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
Aug 09, 2014 | Hayward Pool & Spa
Code 1F
"IF" or" Ignition failure", simply means you heater didn't fire. Be sure your gas is on,and if on propane be sure there is at least 30% in the tank (and the valve is open).Also check whether your "Glow plug" ignitor Glows, or your spark ignitor sparks (depending on which kind you have).
Oct 22, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have model # p-m267a-nc-c it comes on I git error cfh then after a while i git hl2 and it wont heat after that. HELP Please TKS
"CFH" is Call for heat. That means your heater is trying to fire (not an error code). "HL2" is an error code which stands for "High limit #2". This error means the water in the heat exchanger is too hot,and the heater shuts itself down to prevent damage. Most common causes are poor water flow .Make sure the correct pump is running,and you have at least 10psi on the filter gauge. also be sure that the bypass valve is at least 1/2 way closed.The Bypass valve is located on the return line after the filter just passed the first tee.
Oct 12, 2010 | Rheem 266K to 399K BTU Swimming Pool...
1F Error Code on Hayword Heater
IF stands of igniton failure. Many things can cause this. Most notable, is a clogged or dirty burner orifice. The two middle ones are the most important. But i would clean them all out. They remove with a 5/16" wrench. Improper gas pressure could also cause this. However, you need a special tool, a manometer, to read this.
May 05, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
H250 inground pool heater turns on 5 seconds shuts off flsahing 1f
This is a code for ignition falure. If you are getting a pilot then it means your Ignition module is not sensing the flame and shuting the gas down. This could be pilot wire burnt and grounding or a pilot flame not reaching the sensor or a bad ignition module. This is the expensive part so look into the other things first. Good luck.
Jun 26, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
