Question about Whirlpool Duet GHW9150P Front Load Washer
How do I empty the pump? - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
If you are attempting to clean the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
To avoid the mess of any residual water that may still be in the drain pump and/or drain lines, use a wet/dry shop vac and pull a vacuum on the drain hose. If you do not own a shop vac, have some towels ready and place them around the drain pump clean out trap. Crack the trap cover open and allow the water to trickle out. Soak up the water with the towels.
If you have any questions about these procedures, please post back and let me know. I hope you find this information helpful.
Posted on Nov 10, 2010
My Hotpoint Aquarius washing machine WMA58P will not empty.
Recheck your electrical connections. Check for power reaching the pump with a suitable tester. If there is no power then it might be the controller or that it might not be requesting the pump to operate.
Be patient...
Apr 17, 2017 | Hotpoint Washing Machines
Car goes dead when gas tank is half empty what is the problem
Faulty fuel pump. Probably internal ground in pump. When tank is full, the gas will absorb the heat the pump generates keeping the pump nice and cool. Tank half empty, the pump is now exposed, with its long nose stuck still deeply into the bottom of your 1/2 empty tank. Now with fuel pump exposed, it gets hot, the gaskets and things inside the pump swell up, and the pump fails to turn. Your car quits untill the pump cools off, (if your lucky) can be only a second between cool and hot/non function.
Dec 11, 2013 | Jaguar Cars & Trucks
Won't empty & will not spin
These machines won't spin untill the're empty, so your problem would probably be the drain function. It's not uncommon for the pumps in these machines to get something jammed in them or even for the pump itself to fail. The pump is accessed from underneath the cabinet...Most important to empty the machine before removing the pump!!!..Probably best to call a tech, because the pump resistance should be checked.. A failing pump can cause other components to fail as well......Not a big job for a tech. Good luck...Nomess
Jun 01, 2010 | Fisher and Paykel WL37T26DW1 Top Load...
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint wma32 wont empty
Chances are you have a lid switch problem or the most likely cause could be a drain pump obstruction.You could use a wet dry vacuum and connect it to the drain hose in the back of the washer to empty the water.Once the water is empty remove the hoses that are connected to the drain pump and feel for the obstruction in the pump.If nothing in the pump,it would be the lid switch.
Jan 31, 2010 | Washing Machines
Pump not emptying on WMA74
behind the machine
remove the lower rear cover and the pump is in the corner.
empty water by putting the drain hose lower than the machine into a basin to syphon it.
Jan 27, 2009 | Washing Machines
Water will not empty
Hello
you either have a blockage in the filter or you pump is not working.
how to check is diconnect the waste pipe and lower it to ground level if the water does not empty then its a blockage. if it empties then its the pump.
other things it can be is a blockage where the waste pipe is connected or a loose wire to the pump..
Dec 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
55 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
