Question about Philips 42PFL3704D LCD TV
No power does nothing at all no lights no clicking of relay NOTHING
  • 10,515 Answers
There are a couple of things that could cause this, unfortunately there is no reset for this televisions and it will have an internal failure at this point. I will try to explain the possibilities the best I can, assuming you have checked to ensure the outlet is working and the cord is firmly plugged in on both ends.
If the set is completely dead then there is a possibility that the AC fuse is blown, but that would be rare unless you had a power fluctuation of some sort, this type of replacement normally runs $100-$125 in your home....if it not he fuse then....
First you could have a failure in the power supply, we have seen some capacitors fail in your model and cause funky problems like this. If this is the case you could be looking at somewhere around $175-$200 to fix the set. IF the power supply had to be replaced you could be looking at $350
Next could be the main board, this would not be good news because you could be looking at $400-$500 for the repair (I know this is up there in the price range and most likely getting over the cost of a new set)
Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set. The panel in your TV is about $800 just for the part.
Any of these could cause your problem, but it will require troubleshooting to determine the exact cause of your problem. If you have experience, and test equipment and would like to attempt some troubleshooting I will be happy to assist you, however if you do not have equipment or experience then you would need a repairman at this time to get an exact diagnosis. I am sorry that I don't have a quick fix or easy answer for you on this one, it is definitely an internal failure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 10, 2010
When turn key nothing happens
check connection and wires at battery for damage or corrosion if good check for power to ignition switch if no power check for damaged or shorted wiring if good turn key and check if power going to relays or accessory's at fuse panel if no power switch may be bad
Apr 08, 2014 | 2002 Saturn S-Series
98 grand prix won't start battery good tried jump start nothing removed glove box relay clicking ? checked fuses under hood in fuss box all good will not turn over clicking noise from relay...
Better check with a test light for power to the small wire that goes to the starter from the key switch. If no power need to check for a neutral safety switch or fuse. Or the starter you got is bad. Alternator will not cause not to crank over
Aug 03, 2013 | 1998 Pontiac Grand Prix
Truck wont start
If you have no fuel pressure at the engine when key is on, the pump is not coming on. Check fuel pump fuse, check fuel pump relay (relay should click when key turned to on-put finger lightly on it and feel for click when someone turns key to on). If no click, signal from computer may be lost, ground for relay may be lost, or relay may be bad. If it clicks, wiring from relay to pump may have failed, or the relay's main power source may not be there at relay-find the fuse link or maxi-fuse that powers that relay. One terminal at relay should be hot at all times-can check for that with a test light.
If pump is working and you do have fuel pressure, you will need to check injector circuit. Post back if questions, or need further help.
May 25, 2013 | 1992 Dodge Dakota
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
My 99 caravan has no running lights but all other lights work. i found 2 fuses under dash but no power going to them. it is not equiped with day time running lights. i can hear relay clicking when turned...
Park lamp relay location under hood fuse box. Park lamp relay is controlled by the BCM - body control module .Fuse #22 40 amp powers park lamp relay .
Dec 26, 2017 | 1999 Dodge Caravan
Sharp LC-45D40U Won't Power On! Need Help!
If doesn't give error code most probably is something wrong with 5 and 3.3 volts lines. Check first the power supply and try to start the tv with all connectors removed. Let only the one between main pcb and power supply. Look for shorted voltages lines.
Apr 10, 2008 | Televison & Video
No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Feb 28, 2006 | Panasonic SC-PM19 CD Shelf System
Philips 42PFL3704D LCD TV Logo
244 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
