Question about Danby DPAC8020 Air Conditioner
Everstar MPM1-10CR-BB6 My unit keeps showing the message "P1" whenever I power it on. Then it turns right back off. Canu help me?
  • 8 more comments
  • kated53 Jun 19, 2008
    Unit was working fine....turned it off and now when I turn it on,....just get the P1 error message. There is no water anywhere in the unit..no buttons seem to be working. Cleaned the filter...now what? Would greatly appreciate some help.
  • Michael Poreda Jul 07, 2008
    Usually, when I turn it on, it says "P2" and blows air. Now it says "P1" and does not.
    My everstar portable A/C used to say "P2" and began blowing cold air when I turned it on. Now it says "P1" and does not blow any air.
  • hutchins Jul 07, 2008
    what are the two hoses in the back for. I just bought one and no insturctions. do you need to put water in it? where?
  • blair1058 Jul 08, 2008
    Yes! I have the same problem. No air and "P 1" on the display.
  • friscon1 Jul 15, 2008
    I have exactly the same problem. Before it was working very well and all of a sudden the "P1" shows up and the A/C doesn't work anymore...
    OK, I had the same problem.. "P1" message. I dumped almost all the water and turned it back on. IT WORKS now... I hope this helps...
  • dbelanger Aug 06, 2008
    My everstar air conditioner only will show P1 and does not turn on.
  • Anonymous Aug 29, 2008
    Drain the water and then hold down the turbo button
  • gonzalezal42 Sep 15, 2008
    i have a everstar portable air conditioner model mpm1-10cr-bb6 and P-1 keeps showing up how do i get it to work.
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely (you do not need to have it plugged in for this method) and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion. I do it every few months and of course when winter approaches.
I like this air conditioner and have had really nice luck with it. A little loud but who cares. That's why there are SUBTITLES on the television.
Hope this helped.
RoC
Posted on Jul 11, 2008
  • Janet Harvey-Coutrayer
    Janet Harvey-Coutrayer Jul 17, 2012
    Just tried it. I was thinking you had to hold down two buttons. Just turbo.
    Novelist:
    Champion:
  • 230 Answers
Press and hold the turbo button as you restore the power. It will start making noises as it runs through some tests. It will probably then give you a more specific error message. In many cases it is an excess of water in the drain pan.
Posted on Jun 27, 2008
  • Don Berry Jun 30, 2008
    I believe that this may be the error to warn you that the drain pan is full of water. Try dumping the pan.
I tried emptying the unit of water. The water can be drained through the tube in the back. Take the stopper out of the tube, then drain it into a bucket. I did that, then turned it back on and pressed turbo for a few seconds. Eventually, the "water indicator" light started blinking. I then had to drain it again, and about another gallon of water came out. After that, the unit started blowing cold air again.
Posted on Jul 07, 2008
Not sure, but after I drain the unit, remove the black plug located at the bottom on the back of the unit, the P1 & P2 error code is gone.....now unit is working fine.......
Posted on Jul 09, 2008
My cooler will only run on low---the fan mode works on low medium and high---but cooling mode starts at high and switches to low and will not change....
Posted on Jun 27, 2011
Just bought a everstart air conditioner 10000 btu, and it showing P1, then it disapear and show 62 which is the default set. it only blowing air, not even cooler.
P1 means drain the water, I just bought from a store. never used it. and there is no water to drain
Posted on Aug 06, 2008
GRACIAS POR FIN ASE FRIOOOOO GRACIAS A USTEDES
Posted on Aug 08, 2008
Tried holding down turbo and error P2 came up
Posted on Jun 29, 2008
2 Suggested Answers
SOURCE:
SOURCE: Everstar MPM1-10CR-BB6
Press and hold the turbo button while plugging in the unit. The AC will cycle through a few tests and mine showed that it had excess water. I have long vinyl tubing so the unit could drain outside the window but it thought whenever it would start or stop there was excess water (thus stopping the flow). I drained the excess water out of the line and voila
Posted on May 08, 2009
Whats does P1 mean on my portable ac unit everstar model # mpn1095cr-bb6
What if you don't have the drain hose that came with it can you use any hose?
Jul 30, 2012 | Heating & Cooling
Everstar portable AC not cooling, what do I do?
Same thing happened a few weeks ago. My wife said " its not cooling". I read the manual and it says., Clean filters ...we did and hello. works fine. She was so frustrated she was going to take it back. These filters accummulate dust fast. So check there first. Hope this helps.
I would lkike to know where to get replacement filters or an extension exhaust duct.
Aug 29, 2009 | Danby DPAC8020 Air Conditioner
Need manual for mpm1-10cr-bb6
The unit shuts off whenever the water tank fills up. It's on the right bottom side, just pull it out and drain the water, when you put it back in the a/c will turn on again.
Jul 13, 2009 | Danby DPAC8020 Air Conditioner
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Need manual for EVERSTAR model MPM1-10CR-BB6 air conditioner
This site has the manual. It doesn't state the same model, but it's the same manual.
http://www.supportuscenter.com/product.asp?specific=90
May 17, 2009 | Heating & Cooling
Jul 08, 2008 | Danby DPAC8020 Air Conditioner
PORTABLE AIR CONDITIONER (EVERSTAR BRAND)MODEL MPA08CR NEED HELP TO OPERATE THIS ITEM
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER MPM2 , MPM210CEBB6
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Jun 21, 2008 | DeLonghi PAC85 Portable Air Conditioner
Everstar portable air conditioner
Sep 08, 2007 | Danby DPAC8020 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
12,378 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
mintvl
Level 1 Expert
Bill Long
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
