Question about Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player
I have a mustang 2009 and added a aftermarket radio and I hear a pop every time i turn it on?
  • 87 Answers
The Mustang use a 6 volt remote turn on so you need to reduce the voltage by adding 2 resistors. Get two 10ohm resistors and tie the top end together and that will be the out put to the car. The other side will have two wires one is the positive remote from the radio and the other goes to ground. It shouldnt pop then.
-david
Posted on Nov 10, 2010
Testimonial: "Good Deal! Great info!"
My 2007 ford F150 stereo cuts out intermittently when the headlights turn on both with the auto setting and when turning on manually
Intermittent windows, gauges, radio - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Dec 4, 2009 - Intermittent windows, gauges, radio Super Duty & Heavy Duty. ... How about headlights, which you didn't mention? Does the vehicle .... You know how when you turn off your truck, and the radio continues to play until you open a door? .... I cutthe corroded section out and put on a new battery terminal. Radio cuts out when headlights turned on
Oct 24, 2013
Headlights on and radio turns off...
Dec 28, 2010
Electrical Glitches / Electrical / Electronic Diagnostics / Fixes ...
Dec 9, 2009
Odometer Blackout Problem Fixed!!!
Jan 25, 2004
More results from www.ford-trucks.com
Nov 24, 2015 | Ford Cars & Trucks
How is 2001 Mustang GT parasitic draw on battery related somehow to FU 27 and FU39? Battery drains overnight but I cannot narrow down a faulty component.
Allfordmustangs.com has an article if you Web search your car with fuse 27 and 32 as part of the search. It blames the GEM as part of the problem(wiper) and also points out that the radio has several power feeds. Fuse 27 is hot all the time, but fuse 32 is only hot in ACC or Run. So as long as you can test fuse 32 to be hot in only Acc or Run, it should not drain the battery in Off position. You might want to test the ignition switch to verify it is really turned off.
The all mustangs article had different symptoms, as you did not indicate whether the fuses popped.
The wiper motor is suppose to derail and turn off. If you can unplug the wiper motor overnight and the battery stays up, you would know that it is either the wiper motor or wiper control. The radio is on the other fuse circuit. But whether the radio can drain a battery in a short time, you need to measure draw, but if the fuse pops, the battery should stay up. Again, disconnecting a circuit like a radio, and then having the battery stay up, would point to the radio circuit being at fault.
Oct 14, 2014 | 2001 Ford Mustang GT
My 2001 impala speakers are make a popping noise with key on or key off
factory stock radio:? , not custom aftermarket radio added and wired in to car wrong?
well unplug the radio connectors. does it pop now.
yes, then its not the speakers. popping.. how can they , not connected?
no, then , check for 12vdc at the radio power connector wire
with key pulled. (off)
got power on the radio now,. that is wrong.
use a rubber hose to your ear to find true object popping.
Jun 09, 2014 | Cars & Trucks
My 09 Mustang wont start , it dont even crank
You have a serious wiring issue. No way it will start if engine does not crank. Why isn't the starter turning? Is it good? Is it getting power? if not, did you go to power source and check? start relay?
Aug 31, 2017 | 2009 Ford Mustang
How can i instal my new radio in my 2002 ford mustang i dont know witch wire gos connected
best buy or most stores that sell new car radios sell wiring adapter kits that simply plug in to your existing harness. It is the easiest way to install an aftermarket radio
Apr 24, 2010 | 2002 Ford Mustang
My stereo in my mustang was stolen and all the wires were cut i need to know what wires do what so i can install an aftermarket cd player
Okay it is very simple but if you don't know what your doing you should google this info "1999 ford mustang stereo wiring diagram" and something should pop up and you can usually print it out or download usually I print them out.
Good Luck!
Feb 07, 2010 | 1990 Ford Mustang
2010 mustang radio issue
Mine is doing the same thing. Did you find a solution
Jan 01, 2010 | 2009 Ford Mustang
2002 mustang gt timing and air/fuel
Sounds like you are very close. Perfect it 14.7. Are you using an aftermarket computer, or stock? Will need an aftermarket, as stock will not handle the added features you put on your car.
May 25, 2009 | 2002 Ford Mustang
Adding amp and speaker, no rca amp jacks on back of radio
well you can installl anything you want into your vehicle you just need to know how!!
Apr 14, 2009 | Car Audio & Video
Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player Logo
97 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
