Question about Sony Ericsson Z520a Cellular Phone
Battery drains fast
My sony ericsson Z520a's battery drains fast and it gets hot when i recharge it, or even if i don't charge it. I'm worried it might explode or something. please help.
  • Anonymous May 12, 2009
    This phone has blown through four chargers since I got it three years ago, it constantly shuts itself off or makes it so I cannot call people. It quits in mid-phone call and makes a clicking noise in my ear. My friend had the same model, and suffered the same problems. It's no good. Get a new phone.
An internal circuit probably shorted. have it checked by a cellphone technician.
Posted on May 11, 2009
Actually my mobile battery is draining very fast even i am not using my mobile just except accepting the calls on my phone Even im closing all the applications properly im fully charging my mobile it shows...
Does the phone usually gets hot before the battery runs down?
Try changing the battery, maybe the battery cell is weak.
Let me know what happens after changing the battery, so that I might direct you further.
Take care.
Nov 20, 2009 | Sony Ericsson W700i Cellular Phone
Cannot turn phone on
cetainly the problem should be with the charger or the battery of the phone
Nov 12, 2009 | Sony Ericsson Z520a Cellular Phone
My sony ericsson K550i cellular phone won't switch on even the battery has been charged for hours...
You may have let your battery fully drained before you recharge it. If that is the case, it will never charge and turn on the unit. Using a voltmeter, check the voltage. Any voltage lower than 3 volts will not allow your battery to be charged no matter how. You need to "shock" it before you charge it. To do so, use a 9 volt battery and connect its terminals to the battery terminals with same polarity. That is, positive to positive and negative to negative. Do this for one minute or until the battery gets warm. Insert the battery then charge. If it successfully charged but dies early, you need to replace the battery. You may opt to borrow a friend's battery to directly check if it's really the battery.
Sep 26, 2009 | Sony Ericsson K550i Cellular Phone
I change the bettrey by new one
Hi.
You should use a new battery like this:
First fully recharge it. Then just use it empty.
Repeat this like 3-4 times.
Your battery should be better now.
Sry my english.. :D
Aug 12, 2009 | Sony Ericsson K530i Cellular Phone
Battery
i have nokia 7610 but gosh mya battery easily get drained, it tooks 3 hrs of use ,im using the correct battery -5c something like that,, pls help me find the solution
May 28, 2008 | Sony Ericsson J220a Cellular Phone
Battery charge is finished very soon without even using it( in about 5 hours)
The proper way of charging the battery on your phone is by waiting for your phone to indicate that it's running out of powe but not completelyr, if you frequently charge your phone even if it's not yet necessary(battery life indicator show half-way) the ability of the battery to store power will deminished hence the battery life is shorter. Last resort would be trying another battery unit to test if it's your battery of your phone that's causing the unsual battery drain.
Or you can try the following steps on conserving your phones battery life;
  • Turn off your Infrared and BlueTooth when not in use. Even when they are not in use, they do keep drawing power looking for signals.
  • Switch off the vibration alerts. Vibration causes a lot of power usage thereby making battery drain fast.
  • Re-adjust your screen brightness to around 50%. Screen power is another silent killer.
  • Usually, presetted Backlight durations are of pretty high order, this can be readjusted to get more from your battery. Try reducing the Backlight duration.
  • Often we don’t understand that playing games requires Light, Sounds and Shakes. This in turn leads to tripling of battery drainage.
  • Lower Ringing and other message sounds. This too helps saving a lot of battery.
  • Finally, do charge your battery before it gets drained fully. This enhances battery life.
May 05, 2008 | Sony Ericsson K800i Cellular Phone
I can on my w850i phone
Red blinking power button means low battery.
You'd better charge it... By the way, Li-ion batteries should not be drained completely. They will live more if you don't let your phone completely drain the battery before recharging it.
Hope this helps.
Mar 11, 2008 | Sony Ericsson W850i Cellular Phone
Fast battery drain
their was a deffect in the phone so plese check it to your near company authorized service center
Nov 10, 2007 | Sony Ericsson K700i Cellular Phone
Digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
Oct 14, 2006 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Ericsson Z520a Cellular Phone Logo
132 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
