Question about Homelite Garden
Homelite trimmer ut 15151 How do I replace pull
Homelite trimmer ut 15151 How do I replace pull start cord .In particular removal of the clutch when I don't have the correct tools. The cord just pulled out when I went to start the trimmer.
    President:
  • Homelite Master
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers
Posted on Nov 10, 2010
Homelite model ut 15151
I don\'t think so. the carb doesn\'t suck from there when engine is running
Jul 24, 2013 | Garden
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to guitar0589@comcast.net. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
Jun 28, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite st 155 pull cord wont pull out on my weed trimmer
this works by a spring, and there are 4 bearings in a clutch that help it to engage. Through wear and tear this can get to where it just doesn't work well anymore and needs cleaned. Remove the four screws that attach the motor to the clutch assembly. This will give access to the pull cord. Remove and be careful for the spring likes to shoot out when you remove the 4 tabs that hold the spool in. Clean, lubricate, reinstall, and you should be back to trimming.
Jul 06, 2009 | Garden
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
192 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
