Question about Dryers
There is no heat. The drum spins and the timer works on all cycles--the only thing wrong is there is no heat.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Dryer is not heating, timer does not move, drum spins, all air flow is clear
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Dec 27, 2010 | Whirlpool LGR8648PQ Gas Dryer WHITE on...
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Heat works on all cycles, drum spins, clothes are not drying they are just getting hot..
heatman101
Dec 19, 2010 | Maytag Dryers
The clothes are still wet at the end of each cycle. The water is not spinning out. Can this be fixed?
I assume you are saying the spin cycle is not working. Is the drum turning at all (for example, during the wash or rinse cycles)?
If it is, then the problem is most likely in the controller (or timer).
The things that have to work for the drum to move are the controller/timer, the motor, and the gearbox.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Bosch WFO2060 not spinning at spin cycle.
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jul 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
