Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
The photos my new MX870 prints have horizontal lines thru them evenly spaced about 1/4 inch apart. The color is also too strong/heavy. The MX870 display model at the store printed fabulous photos. I think there must be some sort of adjustment that needs to be made to my new printer. It prints everything else just fine.
5 Suggested Answers
MJS_1
  • 150 Answers
SOURCE: Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Posted on Apr 24, 2008
rhoncruz
  • 134 Answers
SOURCE: white bands on color photo prints
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Posted on Dec 01, 2008
  • 390 Answers
SOURCE: vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Posted on Apr 26, 2009
BuzzFlewhart
  • 655 Answers
SOURCE: What should I try to
Sounds like your print head needs cleaning. Refer to your owner's manual on how to do it. Pretty simple.
If you don't have the manual go to: http://www.retrevo.com/support/Canon-iP100-Printers-manual/id/16010ci076/t/2/ for a FREE copy.
Posted on Nov 22, 2010
Is there a way to get rid of horizontal streaks?
1) Inspect, clean and reinstall print cartridge.
2) replace the print cartridge
3) Replace the charge roll assembly. Some call this the fuser assembly.
Aug 15, 2014 | Dell 5130cdn Color Laser Printer
Why are there Horizontal lines on copies spaced every 3 inches apar?
Download the following manual and check pages 1-293 through 1-308. The main problems with line on the page are do to (1) bad toner cartridge, (2) bad transfer belt and (3) bad fuser. If you want a more detailed explanation on how to get ride of lines let me know.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%203130cn%20Full%20Manual.pdf
Aug 13, 2014 | Dell 3130cn Color Laser Printer
After every line of black text there is a light blue line.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 01, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Hp 8500-printing yellow lines across photo prints
I have an HP 8500 printer. When printing photos it prints lines spaced 1" apart accross the entire photo?
Dan
Oct 31, 2009 | HP LaserJet 8500 Color Printer
Canon MP 830 gaps in printing
Uninstall the printer driver completely, then reinstall the driver again.
Aug 06, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Printer is Not using all the colors when printing?
if you download the ssc you can do a power clean if you dont have this tool let me no
Nov 16, 2008 | Epson Stylus CX9400 Photo Printer
Black horizontal lines across pages
If they are the same distance apart every time then suspect the problem to be caused by the components in this order First the drum that is in the print or xerographic module, the charge and cleaning roller are located in that module also. So I suspect that first.its .Located above and to the right of the toner cartridge. Secondly it could be the roller on the toner cartridge, that would occur probably every 1 1/2 to 2 inches apart, the drum would cause the defect about every 3 inches. It less likely could be coming from the fuser, and if the fuser was causing that you should also have a lot of jams. There is also a transfer roller on the right hand door that could be causing it, but that would be exceptionally rare.
If the lines are random and have no consistant spacing, I would suspect the power supply then the laser.
Oct 28, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Hi George,
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
547 people viewed this question
old marine
old marine
