How to Replace a Headlight Bulb
(DIY Complexity: Easy / Time: 0.9 hour)
Parts:
1. Headlight Bulb
Tools:
1. Screwdriver
2. 1/4 in. Drive Ratchet
3. Socket Set
HIGH PERFORMANCE HALOGEN HEADLIGHT BULB -- Low 45/high 65 watts, Dual
C-8 filament for both high beam and low beam; 100 percent legal halogen
headlight bulbs; Features the whitest and brightest light color similar
to daylight for safer night driving; Meets all US FMVSS 108 and Canadian
CMVSS 108 requirements.
Steps:
Step 1 Open the hood and locate the headlight assembly.
o Tip: Most headlight assemblies have a place in the rear to gain access to the headlight bulb.
o Tip: It is recommended that headlight bulbs are replaced in pairs.
o Tip: Always make sure the struts on the hood can fully support the weight of the hood so that it does not close on you while working. The use of a hood prop can securely hold it in place.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 Gain access to headlight bulb.
o Tip: It is a good idea to check the high beam and low beam headlight bulbs at this time.
Step 3 Disconnect the wiring harness and replace the old headlight bulb with a new one.
Remove the retaining ring from the base of the bulb, then......turn the bulb and remove it from the headlight assembly.
Step 4 Turn on the headlights and check high and low beams to verify repairs.
Hope this help (remember comment and rated this).
i did, everything looks good, i rode it home and it started working? which doesnt make me feel better, thinking maybe the stator is the problem,
