MY CANON NP6016 HAS A E7 CODE AND WILL NOT PRINT. WHAT DOES THE E7 CODE STAND FOR?
  • Office Equip... Expert
  • 242 Answers
If the error is E007 - fuser film off track and will not repair it self
if you don`t know to replace call for tech.
Posted on Nov 12, 2010
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Error code 001
Did you try disconnecting it from the power for a few hours to reset the unit?
Mar 17, 2008 | Office Equipment & Supplies
Error code E7 Alarm lights flashing, can't print. says ink absorber is full
The number to call, in the United States, is 732-521-7230, which is their New Jersey parts center. Get new absorber.
Nov 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code E7
check your exposure lamp to fix this
Oct 09, 2008 | Sharp AR-5316 Advanced Digital Imager...
Pitney Bowes C180
There should be another set of flashing number after the E7.
There should be another 2 digit code.
This will help determine where the problem is located.
The E7 error code is a problem with either your automatic Doc Feeder or the the sorter if there is one installed.
If there is a sorter/collater, then also let me know if it has a stapling unit installed or not.
Jan 24, 2008 | Office Equipment & Supplies
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
HELO
E7-00? = At initialization the white level correction cannot be completed.
You have to clean the white reference plate. Lift the Doc-Feeder, identify the white strip and clean any pen-marks or dirt!
BUT the rest of the code would help!!
  • E7 codes have sub-codes (read by pressing the ‘Print’ button)
  • E7-03 = "Laser Output Error"
  • E7-04/E7-05/E7-12 all refer to problems with the digital reading & laser output
  • E7-15 = Copy Lamp Output problem (doesn’t see the Exposure Lamp light)
  • Nov 19, 2007 | Sharp AR-5316 Advanced Digital Imager...
    Canon Pixma MP150 - Error code E7, light C flashing
    Try removing cartridges and manually claening the heads with cleaning solution and cotton bud (q-tip) replace. Print. No luck? Now try uninstalling and reinstalling printer.
    Mar 13, 2007 | Canon PIXMA MP150 All-In-One InkJet...
    90 people viewed this question
    k24674
    jasbo
    jasbo
