Question about Sony NWZ-S615F Walkman Video MP3 Player
It wont charge
I have a sony nwz-s615f and all of a sudden it wont charge anymore when i plug it in it goes to the screen that says every moments has its music the bar loads and then it says low battery please charge but it wont charge
  • 2 more comments
  • altine Jun 21, 2008
    i have a sony nwz-s615f and all of a sudden it wont charge anymore when i plug it in it goes to the screen that says every moments has its music the bar loads and then it says low battery please charge but it wont charge
  • Anonymous Sep 10, 2008
    The same thing happend to me what is the problem??????
  • samantha109 Nov 11, 2008
    pink mp3 player nwz-s615f.i plug my mp3 player in and it won't charge.i have pictures and songs on my mp3 player, what do i do to have it get repaired or replaced?
  • Anonymous Dec 22, 2008
    i have the same problem and this makes no sense to me cuz i **** at computers
  • 8,596 Answers
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Posted on Sep 14, 2008
Wont connect to the computer or charge
i need to delete my files om my nwz-s615f but it not connected to my computer
Jul 05, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
I will forward a link to a page where you can get the troubleshooting steps which should resolvethe issue.
Jun 17, 2009 | Sony Walkman NWZ-S616F MP3 Player
Wont turn on or off
my firend had the same problem, he lost his charger, so he brought it over to my house, and it seems that it took about 7 minutes for the "e.m.h.i.m." screen to get off and actually start charging, so just plug it in and go do something to amuse yourself for about a half hour and see if anything changed from when you plugged it in, if you still need help, email me at
Nov 11, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Unwanted Music on Sony NWZ-S615F
when browsing on the unit goto the music folder hit function and select delete.
Sep 23, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
My sony nwz-s615f keeps stalling
i installed sony program but i cant buffering it, can you tell me whats problem
Jul 10, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
MY SONY NWZ-S615F got dropped...
Mine has been doing the same thing. There is a reset button that I have been pushing (near the plug), but when I plug mine in to an external charger it locks up again.
Still looking for a solution.
May 04, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Stuck on on intro screen
Can you remove the batteries for at least a minute or so, and put them back in?
Is there a master reset button?
Did you call the manufacture tech support?
Did you ask the dealer where you bought the unit?
If all the above did not work out, then I would recommend sending the unit back for an exchange or a refund.
Jerry G.
Apr 29, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
348 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
