Question about Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher
NAUTILUS FISHER AND PYKEL MODEL. I NEED TO CHAGE THE SPRINGS TO STOP THE DOOR DROPPING. TKS MIKE
5 Suggested Answers
  • 56 Answers
SOURCE: Door drops down no tension
what do you mean buy the door has no tension. looking at the model number it is the two drawer glide systm
Posted on Jun 03, 2010
ginko
  • 19396 Answers
SOURCE: Hello I have a dishwasher Fisher
Hi.
Please have a look at the service manual here: DW820-DW920-.
Check also: DW920
See also: Service Info
Hope it can help.
Posted on Aug 18, 2010
taran_2005
  • 10515 Answers
SOURCE: how can I access the
The springs you need are Part code 521565P, Service kit DW spring hinge (2). There are two springs in each kit, and the retailer who sold you the machine should be able to get them for you.
Before you start, download the Fisher & Paykel Parts Manual for the DW820 and DW920, manual number 599069. Look at the Tub Assembly diagram, page 6 and find the screws (15) that retain the front panel (31 - 33) immediately below the door. This is the way into the machine.
Turn off the power to the machine. Pull it out and undo the screws (15), disconnect the earth lead to the panel (32) and put the panel aside. Then unclip the supports (34) for the next panel (35) and slide the panel up so that the retaining clips (36) reach the top of the slots in the main frame. There is an enlargement in the slots that allows the clips (36) to come out. Again, disconnect the earth lead and put the panel aside.
Find the screws under the seal (12) that hold the surround to the chassis at the front. There are two more screws (1) at the bottom of the chassis. Remove these screws as well. Do the same for the back panel, but do not remove the surround. Rather, gently pull the sides of the surround away from the bottom of the chassis far enough to get your hand in from the front. You should be able to see the springs on each side at the front near the bottom of the chassis. One or both of these springs will be broken.
Remove the old springs. I found it easier to remove the intact spring (only one was broken) from the bottom first, then the top.
Assembly is the reverse order of disassembly. Fit the new springs top first, then bottom. Watch that the seals don't get caught between the chassis and the surround as you refit the surround. Also, make sure that the earth leads are firmly in place on each panel as you put the panels on, and that the leads and connections are in good condition.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 10, 2011
  • 552 Answers
SOURCE: I have a nautilus dishwasher by fisher and pykel
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Posted on Feb 26, 2011
WONT OPEN AFTER WASH
is it a fisher and pykel front loading washing machine ?
What make and model is it ?
Try cancelling program and wait 4 minutes and try to open door.
Feb 01, 2015 | Washing Machines
Fisher and Paykel Nautilus Dishwasher 01 error approx. 15 mins after starting
01 is a door switch fault. it is possible that the switch is corroded and the moisture is causing it to fail, making the machine think the door is open, and it will stop and tell you this.
if you can open the door, and inspect the switch, see if it clicks when pushed.
Oct 25, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Jun 19, 2010 | Fisher and Paykel (IWL12)
Jun 03, 2010 | Fisher and Paykel DS602 Dishwasher
I have a Fisher and Pykel Fridge / freezer Active Smart
on reading the user manuals, it suggests actually calling the F&P customer service numbers and telling them the pattern of the lights flashing.
They can ?diagnose the fault from the light sequence and can then tell you what u need to have fixed.
Dec 21, 2007 | Fisher and Paykel Active Smart E522B...
Fisher and paykel vertical freezer N308 model
bec,
Sounds like you are freezing up! The coils are so frost-laden that they will not allow the unit to function. The unit will need a complete defrost. I'm not familiar with the exact layout of this unit but I can tell you that it needs to be shut down, have warm air blown into the fan area and completely freed of ice. If you just leave it open and turned off, this takes about 2 days.
Possible causes: humidity in the air is condensing...very humid area, too much 'window shopping', not closing the door completely, possible damaged door gasket.
Others: (on older units)
Possible defrost timer problem...or low gas. Try the defrost route. We'll go from there.
Dec 03, 2007 | Freezers
Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher Logo
180 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
