Question about Briggs & Stratton 2200 PSI Gas Pressure Washer
What oil do i use to chane oil - Briggs & Stratton 2200 PSI Gas Pressure Washer
    Genius:
  • 1,015 Answers
For normal usage I would reccomend straight 30 weihgt oil.If you are planning on using it during colder temperaturesI would switch to 10w-30. thanks
Posted on Nov 10, 2010
What type of oil is used
What model and make is it?
Jan 19, 2015 | Garden
I recently bought a used mini van and it did not come with the manual i need to know what kind /quantity of oil and what size oil filter i need for a oil chane
4.5 qts. 5w30 (preferred) or 10 w 30 w/ filter change. Filter is wix 50140 oor Fram 3387a. You should be able to cross those numbers to whatever brand you have available.
Mar 07, 2011 | 2000 Chevrolet Venture
My Chrysler 300m oil light is on and my engine sound like chains what does that mean I do need an oil change
that means u need more than an oil change it sounds like the oil pump went out and runt motor.sorry to say oil chane might help but not for long
Dec 06, 2010 | 2000 Chrysler 300M
How many miles can a 99 v6 camry solara can go before chaning oil
Usually recommend every 3000 miles. If over 100,000 miles on vehicle then I typically upgrade to a high mileage oil
Please leave positive rating as well.
Sep 02, 2010 | Car Audio & Video
2001 Cavalier: how much oil with filter chane...
I believe it's 4 quarts, but I always get 5 as an extra -- add 4 then start the car and let it run for a few seconds (~30 or so) then check level (while the car is level) and add as necessary -- a gauge of how much to add the amount between the low and high lines on the dipstick is 1qt - so if it's right at the low line, 1qt will put it at the high -- ideally, it should be in between the line.
May 17, 2010 | 2001 Chevrolet Cavalier
Oil light wont go off after chaning oil. and engine light oil on
Either there isn't enough oil (add more) or the pressure sensor has failed - test and replace it.
Feb 01, 2010 | 2003 Ford Windstar
Changing oil pan
pull engine from car
Jun 28, 2009 | 1993 Mercury Grand Marquis
Is the gearbox on a 1998 daewoo lanos manual a sealed unit??
Just to confirm that the oil Fill plug to a Daewoo lano manual tansaxle is on the right hand side of the transaxle where the drive-shaft exits the gearbox housing.
You need to jack the car right up and use a torch
It takes 1.8L of oil
Jun 19, 2009 | 2000 Daewoo Lanos
Change oil light stays on
turn key to on position (DO NOT START)
press and release gas pedal 3 times.
leave key on the change engine oil light flashes 5 times than goes away and its reset
The place that changed your oil should have done this for you
Feb 01, 2009 | 2000 GMC Sierra
Briggs & Stratton 2200 PSI Gas Pressure Washer Logo
85 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
