Question about Systemax Computers & Internet
Trying to install new Ultra-ATA hard drive on my six year old SysteMax Tiger PC.My BIOS recognizes the hard drive,but Windows XP will not install for some reason.I've been told to re-install the "rate" drivers,but I don't know if that's the problem.The existing hard drive (60 gigs) has a CRC error at the beginning of the drive (I screwed the hard drive up by messing around with Partition Magic,so I don't think it's the rate drivers).I tried installing a 320 gig hd and that's the one that Windows would not install on.Any ideas?
  • 106 Answers
Update your system bios first. as far as parition magic's related error.. if you were you delete the parition and recreate it, you should be ok. What's the error message you receive when you try to install windows on it?
Posted on Jun 17, 2008
I am trying to install windows Xp onto a brand new installed Hard drive.It goes a little ways into the installation and it pops up a blue screen that says:(( A problem has been detected and windows has...
This is called "The Blue Screen of Death" by techs. It is caused by many things.
Step 1. Format new Hard Drive
Step 2. Read and write a file to formatted drive.
Step 3. Try to install XP again.
Aug 16, 2010 | Computers & Internet
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Sony Vaio PCV-RS720G not recognizing new Seagate Hard Drive. When I first installed the drive with XP OS running, the pc recognized and formated the drive. Since then the original drive that I was going to...
This should be a quick fix. How old is the machine you are trying to update? Do you know if the jumpers on the drive are in order? Is it a SATA or ATA drive? Did a CD or Disk come with your drive? Check jumpers on your old drive and make sure the jumpers on the new drive are similar ( master, slave, cs ). Usually leaving on Master is best. Is anything else on this line, like a CD or DVD? I think you'll get it from here.
Nov 10, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Replace the factory hard drive in my sisters Dimension 2100 with a eagate Barracuda 7200.10 Hard Drive - 80GB - 7200rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal. I go to run the Windows Xp CD that...
If the system is older,you may be limited by the BIOS. Many old systems do not recognize a partition with Windows.
Have you run fdisk for the format and partition setup?
Did you check the BIOS at startup? Make sure it recognizes the drive in BIOS and sees the partition. Hit F2 on bootup.
If it sees the drive, use a boot disk and run fdisk. Check the parameters and then run the install again.
Aug 18, 2009 | Dell Celeron M, 1.3 GHz (SL86L) Processor...
Hard drive spins up but windows does not see it
Depending on your PC make model and BIOS it may not auto recognize the second drive, check those settings. and or it might not support the drive size, in which case look for a BIOS update for your system. You also might want to use "cable select" on the switches even though you set it to slave it may not like that.
Apr 24, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Got a new hdd 250gb sata the pc can't find it
I have the exact same system you have and have the same problem. Dell quit supporting that system as far as updates to drivers and BIOS updates before SATA drives became readily available.
The short answer is there is no way to boot to a SATA drive on that system that I have been able to discover. The BIOS does not recognize it as a bootable device.
What you can do is boot to a regular IDE (PATA) drive, install the driver for the SATA drive and Windows will recognize it. Place your Page file on the new drive and all your applications and data on the new drive.
It is not ideal, but I have managed to move the majority of files to the new drive and it runs quite well. You have to be diligent about installing new software to the new drive instead of the IDE drive.
There is a program you can buy for about $15 that will help you move applications that insist on installing to the boot drive called App Mover. I tried the free trial and it works quite well.
If you ever get a better answer, let me know.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Dell xps 600 windows booting problem
You would probably do right to reinstall Windows. The bios handed off to Windows long before the splash screen comes up. It is probably a faulty driver or corrupt registry entry. If it was me I would reload Windows
Dec 01, 2008 | Dell XPS™ 600 PC Desktop
Installing new seagate pata/100 hard drive and belkin ata/133 controller
There should be a tab on the back of the actual hard drive where you can switch it to CS "cable select", You just take the tab out of the slot that it is in and switch it to where the cable select is. I am sure that the drive is set to something different or it would be working.
May 24, 2008 | Belkin Ultra ATA/133 PCI (f5u098) ATA...
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Computers & Internet Logo
97 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
