Question about Sony KDF-E55A20 55 in. LCD Television
Replaced xl-2200 bulb still red light indicator blinking could it be the ballast?
    Sergeant:
  • 252 Answers
Look at the output transformers in the high voltagesection of your TV very closely. These transformers have been known to fail sometimes if you look closely you can see the burnt places on the circuit board under the bad transformer. These transformers cost about $30.00. This will fix your TV.
Posted on Nov 10, 2010
Sony Wega kdf50we655 replaced bulb lights flashes green five times then goes red what's the issue?
the 5 blinks is indicating the lamp driver (ballast) has failed. You can get the replacement ballast for your model at the top of the following page
http://tvcircuitboards.com/sony_projection__dlp_circuit_boards
They can also assist with installation information,
Jan 02, 2013 | LG RU-52SZ51D 52" Rear Projection...
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
My red light is blinking 3 times, the picture comes on and then shuts it self off and starts blinking. I have replaced the lamp and shut the lamp door correctly.
Hi,It sounds like an issue with the board that powers the lamp it's called the ballast.The ballast has a sensor that it detects when lamp is not responding or if ballast is not able to provide enough power to light it up,that's when you get the lamp indicator.This is the most common failure .When you put a new bulb in sometimes the ballast is not able to power it since it uses more voltage that what it was providing to the old lamp.The ballast is something easy to replace and it's cheaper than the lamp.Have a bless one!
Apr 27, 2010 | Sony KDS-R50XBR1 50" HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Sony grand wega kdf-e55a20 will not turn on when trying to turn on green light switches to red blinking light (this is not the replace lamp light)
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL-2200.Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
Wrong model showed up on my question - need new reply about part
ORDERED SONY PROJECTION REPLACEMENT LAMP - SHOULD ARRIVE IN ONE MORE DAY - KEEPING FINGERS XXX'D THAT THIS WILL RESOLVE THE PROBLEM - BUT THE TECH WAS EXCELLENT RESOURCE! I'M CONFIDENT IT WILL FIX THE PROBLEM AND THRILLED WE CAN DO IT OURSELVES AND SAVE $200! THANKS !
May 18, 2009 | Sony KV-36FV26 TV
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KDF-E55A20 55 in. LCD Television Logo
283 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
