Question about Maytag Ovens
The oven come on but flame is only about 1/4 and never get to temp
  • 3,083 Answers
You're most likely having a heat sensor problem, and that would mean a bad thermostat. Try replacing it, and see if that gets you going. If that doesn't help, you could have a bad control valve.
Go to the following website, enter your model number, and if they have them, you'll have access to diagrams and parts lists that will help you identify the components:
http://www.appliancepartspros.com/
Good luck, and hope this helps.
Posted on Nov 10, 2010
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
Gas wall oven wont come up to temp.
GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 07, 2014 | Frigidaire FGB24S5A Gas Single Oven
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
Kenmorw built-in oven (Model #30129) won't maintain cooking temp, flame is off and on continously, take twice as long to bake or broil food. If the temp is set for 500, the oven temp might be 250.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
I need correct temperature readings
On most US ovens the high temp is 550f and the lowest is around 100f for warm. I would imagine 1 is warm and 5 is 550f so 2 would be 250 3 would be 325 4 would be 425. Or you could say ribs and slow cooking 2, cake 3, cornbread 4, and 5 would be broil. The only way to know is set each number and place an oven thermostat in there to see what the temp is fer each number. Personally my grand mother cooked on a wood stove and never had a knob, she just shoved the biscuits in the oven and added another stick of wood.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 28, 2010 | Ovens
I have a Whirpool gas range. Everytimme I hit bake and start the oven starts to heat up. After about 20 seconds it shuts off. I got error code E303 so I replaced the oven temp sensor but that didnt fix the...
The flame sensor is bad. Go to repair clinic. com and put in the model and it will pullup the parts for your oven. Buy the flame sensor. It has to 'see' the gas flame to remain open from the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 06, 2009 | Ovens
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Oct 31, 2017 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Ovens Logo
Top Maytag Ovens Experts
Carmen Mikulic
Marvin
Marvin
Sal De
Are you a Maytag Oven Expert? Answer questions, earn points and help others
