Question about HP PSC 2355 All-In-One InkJet Printer
Unit will not print from laptop - HP PSC 2355 All-In-One InkJet Printer
  • Kandi Cook Nov 10, 2010
    Did you install the software on the laptop before trying to use the printing features? Does the laptop automatically recognize the printer when you connect it? Do you know how to tell? If not, try this: Turn your computer on and your printer on. Now disconnect the printer from the computer by unplugging the usb cable connected to it. After you disconnect it, plug it back in to the computer and watch the bottom right hand size of your computer screen at the same time. Tell me if you see a pop up message that says a new item has been connected? Unplug it and try it again to clarify if any changes happen if necessary.
    Please answer the questions above and I will help you solve this problem.
  • HP Master
  • 7,733 Answers
HP Office Jet 4630 E-All in One. Installing to print from 2 computers via wireless network. Wont print from 2nd computer.
It's some kind of communication error. I would suggest uninstalling the printer from the second computer. Also, make sure you go to the website for that printer and download the latest driver that was designed for Vista 32bit. If you are using the included software disc it may not have the latest driver updated that fixes this problem.
May 07, 2015 | HP Office Equipment & Supplies
Unit will not power up
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 12, 2013 | Dell Inspiron 6000 Notebook
I've configured my desktop Brother HL2040 to share but I can't print from my laptop.
Make sure you've got the firewall set to allow printing on the computer working as a print server.
Another simple solution is to pick up an ethernet or wireless print server unit. It's going to cost more, but it's typically very reliable, and doesn't depend on another computer for printing.
Jun 25, 2011 | Brother HL-2040 Laser Printer
How to print screen on my HP Pavilion dv9417cl. The print screen tab is not copying the screen. All functions of the unit is working properly. Is there another way?
PRESS print screen & OPEN PAINT & paste it
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Feb 19, 2011 | HP Pavilion dv9417cl Notebook
The printer is connected with the laptop thru wireless connection. Its getting detected also. But whenever I try to print a page it goes to the printing Q and does nothing
Can you post the printer brand? HP?
Cancel all pending jobs from your print queue. Remove the printer and add it back in from your printer lists.
Of course you can try uninstalling and reinstalling the unit.Of course you can try uninstalling and reinstalling the unit.
Oct 04, 2010 | Office Equipment & Supplies
I have a 4040CDN brother printer that does not want to work - tells me to turn it off and on. But nothing works after that
Is it giving you any error messages either on the small LCD screen or on your pc/laptop screen? Can you print any of the system files from the printer menu directly just to test whether it will print anything at all before trying to print from your pc/laptop? When was the last time you changed your toners or drum unit? Sorry, more questions than answers at the moment.
Sep 13, 2010 | Brother HL-4040CN Laser Printer
I don't know how to activate bluetooth on my laptop.
Look for a key with the bluetooth icon on it printed in blue. If you find it, press the function key + Bluetooth icon key.
There may also be a little switch on the side or front of the unit.
Mar 06, 2010 | Dell Vostro 1510 Laptop
The printer suddenly stopped printing in the middle of a job. Now whenever i try to print it says job waiting and when i try to delete the current prints it says deleting but stays on saying that and...
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 05, 2009 | Lexmark Z640 InkJet Printer
Not working?
You'll need to install the copier drivers to your laptop to get the print options to function. Don't confuse fax functions with printer functions. Having the unit hooked up to the phone line allows you to send and receive faxes. You need to be hooked to your PC/laptop with the proper print drivers installed in order to print.
Aug 03, 2009 | Brother MFC 7420 All-In-One Laser Printer
Lexmark x1150 will not print when connected to HP laptop
Missing driver for unit? Installed software for Lexmark on laptop? If no driver or software installed then do so by going to lexmark.com and download software for unit.
Jun 22, 2009 | Lexmark X1150 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
