Question about Bosch Nexxt WTMC 3300 Electric Dryer
The drum is not spinning but the dryer runs.I tried to reset but still it's not working.What should I do?
  • Bosch Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Buzzes at start up. If you assist spinning drum, it will run normally.
the problem may be a failed start/run capacitor for the motor
have a electrician / service technician check it out
the buzzing will be a frequency vibration caused by the motor as it tries to start but with out the extra voltage generated by the capacitor it will not move
Jan 07, 2016 | Dryers
My front end load dryer makes a humming noise when started then goes to pause
Have you checked the drying drum to see if it spins freely? Open the door and verify it spins freely. if it does then the motor may just be in a bad spot. usually after spinning the drum a turn or two it will get it running. it humms and clicks because of the motor not turning and trips an thermal overload switch and you have to wait for it to reset. Now if the drum dosent turn then you have a problem with drum rollers or something stuck in the way of the drum.
Dec 06, 2013 | Frigidaire Dryers
Lg DLE3777W wont start
if the motor is running and the drum is not spinning check the belt that wraps around the drum and motor. may have broke or just slipped off
Jun 21, 2012 | LG DLE2512W Electric Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Ge dryer model #DHDSR46EE1WW. Dryer will not run- just makes loud humming noise. Replaced the start switch and it still will not run at all. PLEASE HELP!
You most likely have a bad motor. Try to spin the dryer drum by hand with the door open, door swich held or taped down, and while pressing start. This will likely get the motor going. If this works try closing the door and starting it again. If it works now the motor may have just had a hard time starting do to it's position or the drum's postition. If it only works when you help it out manually you have a bad motor or maybe a sticky drum/jammed belt/etc. Good luck!
Apr 28, 2009 | General Electric DHDSR46EGWW Dryer
Drum not spinning - Asko 7705 Condenser Dryer
remove the lid and check for the belt being in place, if not then you need another, if its in place then the problem is electrical regarding the motor, possibly a capacitor, maybe the motor itself hope i have helped a little
Sep 30, 2007 | Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
55 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
