Question about RCA P61929 TV
Can't watch dvd player on the RCA J27430. How do I chance input?
2 Suggested Answers
SOURCE: when we connect the input cables to play WII game
We were able to unlock the video and the dvd and wii game are now working. Thanks for trying to help us.
Posted on Jun 30, 2009
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
DVD PLAYER IS ON WITH SOUND ONLY, TV SCREEN SHOWS NO SIGNAL
One of two things are happening. Either you have the video cable connected to the wrong input on your tv and it needs to be switched or you are not choosing the right input signal choice to watch your dvd's.
If you are using rca jacks, you might have connected the video jack to an audio input. Try reversing them. If you are not using RCA jacks then you probably have chosen the wrong input method. Click through input choices on your remote until you get a picture and sound at the same time.
Oct 14, 2011 | Performance Teknique ICBM-9192T Car DVD...
My TV has coaxial inlet only. Can I connect a Toshiba SD-1300 DVD Player? Thanks
  • You can but you have to add one of two things to make the DVD player with a coax only TV.
  • One you buy a VCR with coax and RCA inputs and outputs. They are cheap enough these days and serve more than one purpose as you can watch VHS tapes as well as run the DVD player to your VCE through the RCA cables. Then run your VCR to your TV and back to the VCR both through your coax. To watch DVD you would need your VCR and DVD player on as well and for VHS you would beed the VCR on only.
  • What it does is provide the RCA input and output your TV does not have. RCA from the DVD to the box and the box run a coax to the TV and that's it for this way.
Regards, Tony
Apr 28, 2011 | Video Game Consoles & Games
Dont have manual how do i change to watch a dvd
It will depend on the model but, you note which input you have the DVD hooked up to on the rear of the set---Component 1? 2? Then you use the input (some Mitsubishi's label it Device) and move until you are on the same input the DVD player is connected to.
If your DVD is HD you will if not using it for HD reception connect to the DTV input which is input on back---again not knowing the model number of your set--it is this simple---watch on whatever input the DVD player is connected to---most need a component input but some will use RCA which is yellow (video) red and white which are audio.
Component inputs require Green to green, Blue to Blue, and Red to red AND SEPERATE red and white for audio. 5 connections for typical component and three for RCA or composite.
Let me know if this helps you by rating this solution as I do this here for free.
REGARDS, SD TECH
Aug 14, 2010 | Mitsubishi Televison & Video
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
My remote control is broken. How do I watch DVD's
Hello Boye4522,
If you connect your Dvd player up via a scart lead directly to the back of your Tv when you turn on the DVD player this will send a voltage to the tv telling it to change to the input that your Dvd player is on.
Job done.
Cheers Little Dish Fitter.
Nov 15, 2009 | RCA RCU300WBL Remote Control
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Televison & Video Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
