Question about Pentair 1 hp WhisperFlo InGround Pool Pump WFE24 ()
My pump would turn on humm for 10 seconds thhen shut off ... i took the motor off , had it rebuilt .. reinstalled , and still does the same thing , its not drawing water at all then shuts off in 10 seconds
  • adam hudson
    adam hudson Nov 10, 2010
    Did they just clean this motor up? Did they replace the start switch? Did they record the motor winding resistance and capacitor resistence when you took it in?
  • John Prohaska
    John Prohaska Nov 12, 2010
    Have you checked incoming line voltage at the motor?
    Have you checked the same voltage with the motor trying to run?
    Have you taken the motor back to the shop that fixed it to confirm that it still runs as it should on their bench?
    How old is the motor?
    Does the pump turn freely when installed?
    It would seem most likely that you have a power supply issue that either caused the motor failure in the first place or may have been the trouble all along. The answers to these questions should help bear that out.
    John
    Top Expert:
  • Pentair Master
  • 5,743 Answers
Bad pump motor replace motor or pump
Posted on May 08, 2016
I have an 85 Chevy K10 with ECM computer and a TBI system I've rebuilt rebuilt a TBI system put a new fuel pump high volume and replace the pump relay now when I turn the key to on
Hello Jesse,
What does not shut off?
And what are you referring to when you say "the 2 second or 3 second turn on.
Please clarify your issue and include some more information on your K10 model and engine.
Apr 17, 2017 | Chevrolet Cars & Trucks
My pool pump humms and then trips circuit. I took it apart a bit to check capacitor and impeller. I was able to unscrew the impeller off without holding onto the shaft. I'm assuming the shaft is stuck...
If the motor just hums and does not turn on then it sounds like the motor needs to be checked out.
You can usually get a few more years out of a motor by having a motor shop rebuild it if they can.
US Parts Center
May 23, 2014 | Hayward Pool & Spa
My '99 Ford Ranger (while on cruise control) just shut off while I was driving. Electronics work but engine shut off. Engine turns over but doesn't start up. Any ideas?
2 things to do. Listen at the tank for the fuel pump to humm for 5 seconds when you turn the key to ON.
2. Spray some starting fluid into the throttle body and see if it starts for a few seconds then. If yes, it is probably the pump, slim chance it's the fuel pump relay.
Dec 23, 2010 | Ford Ranger Cars & Trucks
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
I HAVE A MAGNUM FORCE PUMP. iT WAS RUNNING THIS
It could be the capacitor again, but most likely if it stopped while running, its not that, unless you had a brief power failure. The motor may have a built in thermal overload which turned the pump off. If it only humms then it could either be locked up by something in the impller, or could be the bearings in the motor have failed. If the motor doesn't smell "burnt" then you might stand a change to disassemble the pump. Disassemble the motor and replace bearings. Replace the mechanical seal while you have it apart. OR you could buy a new motor, as it is 10 years old.
Jul 05, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Motor humms but blades do not rotate
Try replacing the capacitor which is the cheaper option (about $20) if still don't work replace the motor.
Jul 31, 2009 | Heating & Cooling
Cold weather does not start
Need to listen for fuel pump humm for proper operation. Shoud humm for about 3 seconds with key turned in the on position. Humm will sound from gas tank where the pump is located. If it does not humm. possible Faulty Fuel pump relay or pump. It will need ferther diagnosis.
Jan 09, 2009 | 1998 Chevrolet Cavalier
Top Loading Maytag washer will not rinse/drain and spin.
you may have a locked up pump causing the motor to not run, check to see if you can turn the belts under the unit, if so then you might have a timer with a burnt contact.
hope its the pump as it is cheaper then the timer to replace.
Nov 02, 2008 | Maytag Atlantis MAV7551 Top Load Washer
Whirlpool duet washer wont run
sounds as if perhaps the hummm is coming form the drain pump not the motor, remove the front cover and you ll be able to acess the drain pump resivior, unscrew it and you find all sorts if things jammed into the pump preventing free spinning, 7 years servicing this unt never saw a bad motor, 1000's of pumps
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Pentair 1 hp WhisperFlo InGround Pool Pump  WFE24 () Logo
126 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
