Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
How do you remove the cartridge from Blanco Classic kitchen faucet?
  • 7,733 Answers
Try this useful specs from Blanco ---->LINK .
Posted on Nov 10, 2010
2 Suggested Answers
  • 349 Answers
SOURCE: remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Posted on Jun 13, 2010
Cartridge replacement
Should be able to order new one at any plumbing supply. Remove handle, then with pliers pull out old cartridge, and push in new one till it seats, place handle back on.
Oct 25, 2013 | Blanco 157-013-CR Harvest Kitchen Faucet...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
How do I remove the bonnet nut from a blanco 1-handle faucet (like their "classic" model?
If you mean the top faucet handle, there is a small round plastic cap. You need to remove this and then remove the grub screw, handle will then pull off. Hope this is what you meant, if not post again. Thanks Paul.
Aug 30, 2010 | Blanco Classic Single Handle Faucet with...
How do I remove the aerator on a moen pull out kitchen faucet?
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Jan 27, 2010 | Blanco Classic Single Handle Faucet with...
My blanco kitchen mixer does not swivel. It is stuck in one place
You need to remove the handle and then remove the top cover to the housing. After the cap is removed you can pull off the spout. It probably needs new washers. You will see what you need to fix it at this point. Just remember to turn off your water before doing this.
Mar 22, 2009 | Blanco CLASSIC 1 Handle Pull-out Spray...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Feb 12, 2009 | Blanco Classic Single Handle Faucet with...
How to replace cartridge on blanco single handle
Somewhere around where the handle fixes to the tap should be a grubscrew of some kind undoing this will allow the handle to be removed this will give you access to the cartridge which can then be removed with the correct socket, obviously you will need to turn off the water supply to the tap first!!
Jan 25, 2009 | Blanco Classic Single Handle Faucet with...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
633 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
