Question about Acer Aspire One Netbook 8.9" Notebook
Changed ram in acer netbook and now will not turn on
    Novelist:
  • 58 Answers
The quickest test, is to try another stick of RAM, or try the original stick again.
Laptops can be very fussy at what memory they work with. I have at least 5 models here (2 made by ACER actually) which refuse to use any but one specific type each.
You say that it won't turn on, but do you mean there is no signs of life at all? or it just doesn't actually boot (into Linux i am assuming).
Try the memory testing mentioned above, and if still no life, try again, but with any battery removed first (after removing the battery hold the POWER button down for 30 seconds - to remove any traces of old electric from the netbooks insides).
The most common problem with all laptops/notebooks/netbooks is a broken charger socket, and this would be the next thing i'd check for. It may just be that it could have broken by coincidence at the same time as you have decided to change the RAM.
Remove the battery, unplug the mains charger from the mains but plug it into the netbook as normal, and 'very' gently rock it from side to side just a fraction, to see if it's loose. Don't be rough doing this as the power sockets are always fragile. Remember you're not trying to see if you can make it move, you only want to see if it is already possible because it's broken away inside.
If it feels loose, now take something such as a wooden match, and gently see if you can see the centre pin in the charging socket move when touched. Any movement in there indicates a new socket may be needed - a good working socket should be solid.
Posted on Nov 10, 2010
I change the ram, and then no boot, no video?
Hi there
There are a couple of things here possibly.
Firstly is the new RAM stick exactly the same speed as the old one? If it isn't then this will allow the netbook to appear to run but nothing will get done because the BIOS may not recognise the new memory.
Secondly, it is sometimes necessary to go into the BIOS settings to tell BIOS that the memory has changed and what it has changed to.
The first thing to try is to replace the old RAM and see if this cures the problem. If it does then it confirms that either a setting change is required, the 2Gb RAM is incompatible for some reason, or you may have damaged dislodged something during the upgrade.
Hope this is helpful
Jan 28, 2015 | Acer Aspire One Netbook 8.9" Notebook
Hi..My Acer AspireOne netbook has stopped working! When I turn it on, I am confronted with a blank screen. It is fully charged, but absolutely nothing happens when it is turned on. The only two butto
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Mar 29, 2012 | Acer Netbook
Can u upgrade acer aspire one d255e intel atom n455 processor with a dual core or more?
No
Unlike PC, netbook's hardware such as Processor, Graphics card cannot be changed once manufactured.
But harddrive and RAM's can be changed
Jul 11, 2011 | Acer Aspire One D255E13438 Netbook
Can i change 1 gb ram to 4 gb ram of tablet pc
Unfortunately the maximum amount of memory that the Acer Aspire One can have is 1/5Gb of ram. This can only be achieved by fitting 1 x 512Mb ram and 1 x 1Gb of ram.
You can put more memory in but it simply wont recognise it.
I hope this helps and thank you for using FixYa
Aug 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
Clicking off by itself
Power source failure, - change power supply inside the PC
RAM not properly installed, - open PC remove RAMs clean RAMs/RAM slots and re-install
Ram corrupted - replace RAMS
Boot sector corrupted - use Killdisk to wipe the drive and load OS again.
Dec 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Netbook won't turn on
check the system ram and try another one
try too boot the the system without the ram ie check whether it gives a beep or not if the ram is ok then there could be a problem with the system bios
Jul 09, 2009 | Acer Aspire One Netbook 8.9" Notebook
Just purchased acer aspire one 150-1786 netbook
You say you just purchased it, It must be under warranty, take it back. If its not under warranty it could be a number of things. removing and replacing the ram is the easiest thing to do. Does anything show up on the screen when you turn it on?
Jun 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
